64L or 55L standard fuel tank?
#31
Better question here: If you find a car that has everything you want spec'd but the extended tank would you go for it?
Obviously if I had a custom order the extended tank is a no-brainer and I would want it. But I'm hesitant to take a car with the regular tank. Should I jump on a car now or roll the dice for a car with the extended tank?
#32
I don't think it's worth passing a car that otherwise suits your specs. The difference in tank size is only a bit over 2.6 gallons. As someone mentioned below, if you are driving in the city, that's only about 40 miles. Yes it makes a difference but it's not night and day.
If you do a lot of road trips, the calculus could change. I'm glad I ordered the larger tank but other options are more important to me.
#33
Oh well, pretty much a moot point now. In the 20 minutes I waffled some other buyer stepped up to the plate to make the 6hr drive tomorrow.
#35
Car with larger tanks will trigger alarm and throw a hissy fit if you choose to take breaks before the tank is empty. Fact.
#40
Addict & Guru
I got both the free larger tank and the free larger bladder options. They really work well together and saved me the cost of Scotch Guarding my seats.
#41
Addict & Guru
Not having the extended range tank wouldn't be a big deal but with the opportunity to spec the car, it's an obvious option to include.
#44
