Rev-matching reprogram after moving to sport gears?
981 GT4, upgraded gears 1-5 with a set of shorter gears from Guard. Rev matching of course now doesn’t always work, maybe 50/50 … does anyone know if that function can be reprogrammed to match my new gear ratios? I have access to both Cobb AP and PIWIS3.
did everything get plugged in and there's not a bad sensor? I've seen that auto blip works perfectly fine with other gearsets. I'm thinking you've got an electronic issue because I used to club race bikes and my translogic auto blip on my R6 started acting weird and then my throttle died, had a bad translogic ecu and once I replaced it the bike was back to 100% perfect with the auto blip
Check the crankshaft sensor?. Everything ive read here says that the reva matching works on gear set changes. Also ask Guard directly.
Basic Sponsor
I would ask Guard but it seems like rev matching works as intended.
What gears did you do? This is the first time I’ve seen 1st replaced I believe.
My 718 GT4 Euro Delivery Thread
Contact me for the best pricing on Quality Parts
- alex@lepetitgarage.us
LePetitGarage.us // @_lepetitgarage on Instagram
I had gears 1-4 replaced with Guards and rev matching still works fine replacing 1st gear dropped it only 2mph
