Stuck coolant cap
Old Nov 9, 2021 | 03:53 PM
ZG911's Avatar
ZG911
Default Stuck coolant cap
When I went to take off the coolant cap it was stuck on super tight and I needed to use a wrench to be able to take it off. Now when I twist it back on with my hands, I need a wrench top remove. I can not see any cross threads, and even after wiping everything down it needs a wrench to remove. Has anyone else experienced this issue? I will probably buy a new cap to see if it fixes the issue (hopefully I do not also need to also replace the plastic receptacle which seems a bit more involved and expensive).
Old Nov 9, 2021 | 03:54 PM
LexVan's Avatar
LexVan
Try when cold.
Old Nov 9, 2021 | 03:57 PM
ZG911's Avatar
ZG911
Originally Posted by LexVan
Try when cold.
Thanks, but the car has been sitting for over a week. It does seem as though it was heated and expansion has caused the issue, but it is in a garage around 70 degrees.
Old Nov 9, 2021 | 04:00 PM
colnagoG60's Avatar
colnagoG60
I had mine replaced under warranty. It was leaking (smelled coolant when driving/after parking/small amount of coolant on overflow ridge), despite being on very tight. Service manager told me that the caps were "problematic".
Old Nov 9, 2021 | 04:42 PM
burnergt4's Avatar
burnergt4
The tab that indicates where you should stop turning is probably broken. I went over this in another thread a while back:
Originally Posted by burnergt4
If you're referring to the user operable cap in the rear cargo area, it's likely because the tab that "clicks" the cap into the place was broken at some point by someone over tightening it. Here's a comparison between a new cap and a busted one:
Note on the new one you can see a little ramp, whereas on the broken one the plastic has been completely bulldozed. Without that little tab providing positive feedback of when to stop turning, you'll tend to over tighten by a full turn and require a couple of crescent wrenches clamped down on each end of the cap in order to get it off again.
It's been said elsewhere in any discussion of the user accessible oil/coolant caps, but you just need to turn it until you hear a single click, like this:
https://youtu.be/lI7yKglaBPI
Any more than that and you risk damaging the cap in a similar way as seen in the photo above.
Buy a new one, they're not expensive: https://www.delawareporscheparts.com...ap-98110604406
Old Nov 9, 2021 | 05:57 PM
ZG911's Avatar
ZG911
Thanks for the photos, yeah mine is damaged. Will be picking one up tomorrow.
Old Nov 10, 2021 | 09:53 AM
MTN's Avatar
MTN
Not sure if this is a common issue but had mine replaced on my Boxster Spyder under warranty as well with about 5,500 miles on the ODO.
