Debating between header brands
#61
Soul certainly has dyno charts on GT4 Long-tube catted Street headers, right on the page where the headers are shown. Comparison runs of stock, stock with tune, catted headers with tune, and catless headers with tune.
#62
#63
I did; just pointing out that the dyno charts for the 3.8 should give you some reasonable assumptions about the 3.4 to help in making your decision. Didn't know if you had seen that they were posted on the GT4 headers, as you might have just not clicked on it once you saw it was the wrong product for your needs.
#64
Hats off to JC and John for the great posts. I have had Cargraphic sport headers on my car for six years and over 100 track days in Texas. Not one glitch at all. They just keep on going. I suspect they will wear out one day, and I will get a CEL, but I have had six years of great service out of these headers. I do take care of my car though. The Cayman S has a third radiator on it and I usually add a few gallons of 109 octane race gas to blend my octane rating up to 95-96. I am not looking for extra power from the race gas, just want to keep the engine happy.
okie981 (08-14-2020)
ITR1227 (09-04-2020)
#66
From: On a pygmy pony over by the dental floss bush
#67
#68
#70
The entire exhaust system on 981 cars moves with the engine/transmission assembly, by design and mounting. Due to the modular design of the Cargraphic sport headers to allow removal of the cats and installation of the bypass pipe, there is a joint where the clamp is by the crack shown in the photo. Without the bracing used in the newer generation of Cargraphic sport headers, the next support for the cat and exhaust pipes after the end of the header collector is where the muffler hangs from the support frame that is mounted to the aft end of the gearbox. As I recall from some BGB Motorsports postings a few years ago, a track car that was aggressively using curbs for a while developed cracks in this area. That's why the bracing was added. Go look at photos on Cargraphic's or BGB's website and you can see the bracing that's used now.
Flexing yes, not aware of any of the newer braced versions cracking in this area. I would go back to who you bought them from and show them what's happened, or go direct to Cargraphic.
Seems like that would take some metallurgical analysis to determine if this is inter-granular corrosion attack as you postulated. Does Dundon offer a modular header that allows removal of the cats to install a bypass pipe? If not, I don't think there is any way to know if a Dundon header would or would not experience a similar issue if not braced like the newer Cargraphic.
#71
#72
flipmeraz (09-07-2020)
#73
I spent my career working for AK Steel in their Research Group and Customer Specialty Stainless Technical Services. In that time I worked with every major exhaust manufacturer in the US and several European manufactures. True, a weld cross section would 100% confirm the presence of chrome carbides in the HAZ. But I've seen enough of these failures to put my money on IGA.
