Cold Weather Shifter Issues
I'm driving a new-to-me May '16 build 981 GT4 with about 750 miles (I know I know). Transmission recall was performed about 200 miles ago and has been working flawlessly until this past Saturday. Outside temp was about 30 degrees F, and I was unable to select any gear whatsoever. It's as if the shifter was locked out of gear. I could freely move it around the Neutral area, but it felt mushy approaching any gear including reverse. I let the car sit and warm up for a few minutes and as the temp rose, things freed up. At first I was able to get into 5th gear, then 3rd, and a few minutes later things were back to normal. No issues for the rest of the day.
Anyone else experience cold weather shifting issues? Could this be related to the fluid fill? Dealer suggested I bring the car to them but want to check with the minds here first.
When was last brake fluid flush? Ive boiled the fluid 2 times and after that i had hard time shifting when its cold out, id have to select 3rd or 5th first before 1st or reverse till temps were up. Maybe try new fluid. Brake flushes cured it for me.
Hmm, that’s interesting. I’ll look into that.
I don’t think they flushed it during the recall. And if not, it’s either 1.5 years old or the same stuff the car was delivered with. One thing I’m sure of is I never boiled it.
