AP Racing Radi-CAL Brake Kit
Also the diffuser is designed on the front so the outer edge of the splitter is replaceable at a much cheaper cost then the entire unit.
I have the AP kit on my GT4 as well. I’ve had the car on track for few events already with the kit installed and it has worked great. I strongly prefer it to the OE setup. It takes a few sessions to calibrate your foot to the pedal, as the AP kit requires less pedal force to get into ABS. After you realize that, it is pure bliss. Changing pads is also much easier than OEM. Once the wheels are off the car, it takes literally a few minutes to change the pads.
At the cars current ride height the splitter hits pretty much everything. But if you had normal car ride height you should be much better off.
Front diffuser images for those curious. We are still working on bringing this to production.
Question
The setup is looking boss. Are you making any major alignment/suspension adjustments to compensate for all the extra downforce?
Please share. Thanks!
We have tarret camber plates up front, changed the springs out and updated the suspension controller settings as well. Tons of other monball bits and etc also.
