help with DME report reading
Old Feb 25, 2019 | 04:26 AM
hyperspeedy's Avatar
hyperspeedy
Default help with DME report reading
hi all, noob here. can you guys help decipher this overrev report?
over rev range 1: 22 / 104.58 h
over rev range 2: 10 / 0.00 h
over rev range 3: 45 / 130.18 h
over rev range 4: 291 / 130.18 h
over rev range 5: 18 / 130.18 h
over rev range 6: 0 / 0.00 h
operating hours 143.76
much appreciated, TIA!
Old Feb 25, 2019 | 08:06 AM
LexVan's Avatar
LexVan
What generated this report? Porsche's software or something like Durametrics?
Can't have zero range 2s when you have pings in range 3, 4, and 5. So, something is off right there.
The over revs in range 3,4, and 5 are very recent. Not good. Would like to see >50 trouble free hours after an event like that, before preceding and making further judgment.
There are other anomalies with your report, but this is the most glaring one.
Curious to your report answer.
Old Feb 25, 2019 | 11:50 AM
hyperspeedy
It was done by an aftermarket shop so I'm guessing durametric? Yes the range 2 one threw me off too
Old Feb 25, 2019 | 12:02 PM
LexVan's Avatar
LexVan
Originally Posted by hyperspeedy
It was done by an aftermarket shop so I'm guessing durametric? Yes the range 2 one the me off too
That may expain it. And why is Range #4 higher than ranges 1, 2, and 3??
Old Feb 25, 2019 | 12:04 PM
hyperspeedy
Why does durametric report that way? How do you calculate the # of hours since last overrev?
What rpm is range 5?
Old Feb 25, 2019 | 12:08 PM
rileyracing1's Avatar
rileyracing1
I would re run that report just to be sure ....
Old Feb 25, 2019 | 12:49 PM
LexVan's Avatar
LexVan
Don't know.
143 - 130 = about 13 hours.
Range 5 is about 8,800 rpm.
Old Mar 3, 2019 | 12:18 PM
BryanCO's Avatar
BryanCO
I would have it read at a Porsche dealer.
Also, in a recent thread, I thought the consensus was that the ranges are not cumulative so there are certainly situations where a car can have more overrev points in a higher range than in a lower range (e.g. rev through ranges 1-3 to range 4 and ‘stay there for a bit’).
Old Mar 5, 2019 | 12:41 AM
hyperspeedy
got a hold of the shop info and will talk to them about it and let you guys know what their take is on the DME report
thanks again all
Old Mar 5, 2019 | 12:52 AM
golfnutintib's Avatar
golfnutintib
something screwy here ... rerun it, or rerun at dealer using piwis
over revs into higher ranges from lower ones can only be like a pyramid
Old Mar 5, 2019 | 08:02 AM
d00d's Avatar
d00d
Originally Posted by golfnutintib
+1
No, as BryanCo accurately explained.
The only thing odd is the range 2 zero hours.
Old Mar 5, 2019 | 08:50 PM
BryanCO's Avatar
BryanCO
From a different thread on this topic
