PCCB specks
Old Jan 15, 2018 | 06:53 PM
Christmas50's Avatar
Christmas50
Default PCCB specks
Looking at GT4 with PCCB and they telling me thickness of the rotors is 11mm. That doesn't sound right.Can anyone please help with that?
I know this brakes are very expensive so just trying to to check it out
Old Jan 15, 2018 | 07:11 PM
smmmurf's Avatar
smmmurf
A dealer needs to take the rotors off the car and weigh them. Thickness is not relevant to PCCB wear measurements. Search the forum for additional information and results from members' cars.
Old Jan 15, 2018 | 07:54 PM
Christmas50
Thank you. I've heard they have special tool to measure thickness too. i did some internet search and this was one of the GT3 owners with PCCB set up
I'll keep searching
Old Jan 15, 2018 | 08:34 PM
Christmas50
Can DME could be used to determent track use?
Old Jan 15, 2018 | 08:38 PM
benben01's Avatar
benben01
FWIW.. When I took delivery of my GT4, I had to do a state inspection.. If my memory is correct, front rotor thickness is 32mm and 28mm for the rear.
Old Jan 15, 2018 | 08:45 PM
Christmas50
And that's for PCCB
Old Jan 15, 2018 | 09:04 PM
benben01's Avatar
benben01
yup yup.... mine is spec'ed with PCCB
Old Jan 15, 2018 | 10:08 PM
ajw45's Avatar
ajw45
PCCBs are measured for wear by carbon density, not width. Weight is a side effect of wear but is not how wear is measured because there is no spec for the starting weight or worn out weight of each rotor. You need to go to a dealer and have them measure the carbon density of each rotor off the car. Each rotor has three read points, each read point has two specs, the reading when new and the minimum reading when worn. The measured reading against the min/max specs of the rotor's read point across all three read points determines how worn the rotor is.
Old Jan 15, 2018 | 10:53 PM
Christmas50
Thank you! The problem is dealer is about 500 miles away
Old Jan 16, 2018 | 06:56 PM
GrantG's Avatar
GrantG
The front rotors are 36mm thick new - if they ever get to 11mm, there will be a very serious issue (you would know without measuring).
Old Jan 16, 2018 | 07:14 PM
Christmas50
They called me earlier and said we measured thickness of the pads not rotors. Crazy!!!!
Old Jan 16, 2018 | 08:26 PM
smmmurf's Avatar
smmmurf
Given the above, it's best if you get this car to a dealer for a full PPI including brake measurements and DME report.
Old Jan 16, 2018 | 08:36 PM
Christmas50
I got DME report and it looks good. Pretty clean. BTW I'll ask them to get me a full report on the car and brakes
