Are you running the same alignment with the street tires or did you remove some camber? Just wondering how the car handled and the tires were wearing if you wanted to switch between the slicks and the street tires. Thanks.
We run the same alignment for slicks and the two street tires I listed and the tires wear just fine. I ran the RE71s down till no tread was left. Did they drop off in grip? Sure, but I enjoyed the cost savings, and they were still fine for DE and drive improvement laps. The 295 street tires are shorter so you will have a lower rake in the rear but if you are already going to street tires, that change is minor compared to the tire type change. The tires below ran the same alignment as the CS shipped with for slicks.
