718CS oil change guidance
Just switched from the 981CS to the 718CS. Anything different about the oil change procedure? In terms of oil measurement do I need a computer or does the electronic dash screen show the oil level. I see the area that shows “oil percentage”, is that the percentage full? If so should it be filled to100% or leave at like 80-90% like on the 981 which was one dash under full? Appreciate your help!
https://drive.google.com/file/d/1-Y6...usp=drive_link
Here is the PMNA procedure. I am sure there are 500 opinions on what the "level" should be. I use 100% or a little more....The scale has green and red areas, so there is your clue.
ChrisPy
ChrisPy
Also for info, the range on the Cosworth ICD from min to max is 0.7l. Can't recall where that is in the tech manual, but it's in there. In my experience the level measurement is really temperamental.
