PDK acting odd 981 CS
My buddy’s 981 CS is having a PDK issue. Suddenly the system is up shifting in places it shouldn’t be. It’s upshifting from 2nd to 4th coming out of turn 1 at VIR. Tried to reset it. Tried manual mode- car was in 2nd and shifted itself into 6th. Definitely not normal behavior. Anyone experience something similar?
It began leaking PDK fluid at the end of the weekend so guessing it will need a rebuild. Surprising his car only has 11k miles. Luckily now you can do a rebuild.
A rebuild is the easy button, although a costly one. A leak and weird shifting itself however does not have only one solution. I had a fairly bad leak and weird shifting on my 981 at the 4-5k miles range. Mine was failing to shift, stuck in gear, and throwing transmission codes. It was finally diagnosed by a competent shop as a differential seal leak inside the transmission. That repair was reasonable and has held strong for a full year with zero issues. The PDK has regular gear oil in the gearbox side and pressurized hydraulic ATF fluid in the clutch pack side. If the ATF leaks into the gear oil it messes up the viscosity throwing off the shifts and pushes oil out of the overflow. YMMV
Basic Sponsor
Atlanta Speedwerks doing rebuilds too.
T-Design9 : Mods and ergonomic accessories bespoke designed for Porsche cars
Memory Modules : remember SC **** settings; A/S/S, PSE, Spoiler, Sport/+ buttons
Phone Mounts : keep your phone up and close and charged
Cupdholders, Sunglass Holsters and more at T-Design9.com
I believe what BGB is doing is shipping them out to ZF in Germany under the Clubsport PDK repair arrangement that PMNA recently announced. The prices from PMNA are much less then going to a local US based rebuilder such as Atlanta Speedworks. These PDKs are not that complicated so you may be able to find a local shop willing to try and sort out the issue. There is a huge thread on PDK repairs on Rennlist in the 997 forum. I suggest giving that a look.
Guide to Repairing a PDK Transmission - Rennlist - Porsche Discussion Forums
Jeff
Jeff
Jeff
