981/718 Clubsport Control Arms
Does anyone know alternatives to PMNA OEM control arms or alternative sources to get them for the 981/718 GT4 Clubsport? The price on these is actually good but the availability is hit or miss from PMNA. The inner arms look to be the same as the standard 991/997/996 inner arms you can get from multiple aftermarket suppliers with the exception of the rears looking like they are the "XL" versions (although the part numbers are the same on the casting, the engraved numbers are different, see pictures below). Can anyone confirm this is correct? For the main arm, all the part numbers are the same (A 991#, see pictures) with the only difference from front to rear or left to right (rear only) looking to be the caster bushings. Can anyone confirm? Lastly, is it possible to only replace the spherical joints when they get loos instead of replacing the entire arm? Thanks
Jeff
Jeff
mikew968 (08-22-2023)
Hi!
Maybe I can help out, although from Europe:
EHRESMANN Racing kann order Porsche Motorsport parts directly from the factory.
Alternatives herover are MANTHEY or LECHNER
Jeff
