981 CS Rear Wing Advice
Hey all,
Since trying to find a used wing is difficult, is anyone using a non-OEM / or Manthey rear wing? If so, any recommendations? ... or does anyone have advice on repairing the CF? I have a poorly repaired Manthey wing that my shop recommends replacing.
Thanks in advance!
Thanks in advance!
Have run 2 different aftermarket wings and also the MR.
https://www.dundonmotorsports.com/pr...ng-kit-981-gt4
This is what is on the endurance car now. Very nice piece of kit. You will absolutely need more front downforce in order to make it work. You can actually feel the downforce with this setup.
https://designsbyjacob.com/products/gt4-rear-wing
Have run this wing as well, until we damaged it unfortunately. Also quite nice but I think it is NLA.
MR wing is fine, but is more of a slight change vs a big downforce delta. And its nowhere near the two options above.
The car with the Dundon wing and giant splitter on 200TW tires will have similar apex speed to a MR on slicks in the high speed stuff. Yes, its that's dramatic.
This company also makes a wing. I personally think it looks awful, but it's cheap and gets the job done.lol
https://9livesracing.com/products/bi...yman-2005-2012
mski993 (04-28-2023)
I think they have those too. Their website is a bit "old school," but if you scroll down, it's called "Cayman GT4 top wing" (pictured on a 981 CS).
https://gettydesign.com/cayman/cayman-wings-987-981/
I added a Verus Engineering swan neck wing this year on my modified 4.25l 981 Clubsport . It may be the same wing that Dundon sells, not sure, as I got the Verus front splitter and rear diffusor from Dundon last year. Dropped my personal best at Lime Rock by .9 to 56.1 (a pro did a 54.8 in the car the same day so I am still a wimp!) in my first session out this year and I was not driving all that well. This after only having the shocks rebuilt and doing no driving since November. Naturally, I am happy with the purchase as I very much doubt I "grew a bigger pair" over the winter.....
https://www.verus-engineering.com/sh...man-981-gt4-45
I don't race so class is not important to me but if you race an MR might be legal in your class while this one probably is not.
Good luck.
Good luck.
mlct (04-29-2023)
Thanks for the info ... probably more than I'm after at this point in time, and I would like to keep the car stock in the event of Club Racing next year.
Also, is that the Jan Haylen car that set those ridiculous lap times at VIR and WGI?
The following 4 users liked this post by 38D:
Good luck.
Good luck.
Jeff
Yes, the ride height is a pain to deal with getting on/off the trailer. I am at 55mm which is way low. I was scraping under braking last year without the wing and I needed beefed up springs (850lbs I think now) to deal with that. They had started it down around 35mm which I could not deal with.
No problems this year on the curbs at Watkins Glen.
SpeedSport in Danbury, CT takes care of my car.
Mark
P.S. as noted the GTA3 cars would smoke the car due to its weight. Not a problem since I don't race. My does have the vented front wheel fenders and the Deman 4.25l mentioned in the post about Jan Heylen's 1.51 lap at Watkins Glen.
Mark
Mark
Mark
Jeff
mlct (07-14-2023)
