Removing wheel bearings?
Anyone know what tool is used to remove the 981 CS wheel bearings? Looked like a triple square 10, but that’s too small.
718 Screw holding in the bearing assembly is MULTIPLE-TOOTH SCREW M12X1.25X45 4 WHT004835
Which uses the M12 triple. I do not see the screws listed in the 981 CS parts list that I have. The hubs are not the same.
I looked...
I looked...
Thanks. After some more digging in the 981 manual, I believe it is also a M12 triple square, which I don’t have in the toolbox.
You got triple D's and no triple square..
Chris P Lewis (09-03-2021)
