Does anyone know what these are for?
Took delivery of the 718 CS MR. (love it!) Got a box full of accessories which aren’t labeled - can anyone identify them?
(I know the last image is for a battery charger - but what kind of charger would fit into that plug?)
thanks!
Battery charger cable - but what kind of charger would fit into that plug?
thanks!
Second photo is for pumping out the fuel cell, the others are to connect a battery charger. have you signed up with PMRSI? You can access the tech manual there which will show use of these and the model battery charger. When I checked the price of the recommended charger it was steep so I just use a regular porsche trickle charger- I have an AGM though
edit, you can also access info here, courtesy of Chris
718 GT4 CS Technical Info Central - Rennlist - Porsche Discussion Forums
John Montgomery (08-07-2021)
As said, the 1st and 3rd pic are for the battery charger. The 3rd hooks to the battery, and the 1st is so you can make your own harness. They also sell an adapter that allows you to plug in a ctek charger to the big Staibli plug.
John Montgomery (08-09-2021)
Thanks, - looks like you can adapt the wires from the C-Tek adapter by cutting and crimping into the Staubli plug yourself.
John Montgomery (08-10-2021)
