Suspension upgrade options
I have a 981 clubsport MR with the 2 way KW shocks. I'm about due for a shock rebuild and just trying to plan for it. Instead of rebuilding I've been thinking to change the set and keep the kw's as a back up set. What have you guys run that you like? I'm considering JRZ's either the series 11 or the RS pro 3's. Thanks in advance.
Unless you are going to 4 ways, you won’t really get any performance benefits. And even then, it will take a lot of time testing to get them setup and extract the value. I’d stick with the KWs.
Take a look at MCS motion control systems.
I have the JRZ 4 ways installed. They were a nice upgrade to the KW's that came on the car. I had a two pro drivers drive the car once installed to set a baseline for me and then I tweak from there based on the track, track conditions, etc. There are infinite adjustments and way above my capabilities but I do like the option of tweaking a bit.
