Michelin slicks on cold days
Hi Folks,
First time running Michelin slicks (wife is running them actually, she is the one that got the CS this year). We are heading to Summit Point this weekend for a DE event with SCCA and had planned to take the CS however the weather has turned very cold. The lows are forecast down into the mid to low 20s and the highs in the upper 30s to low 40s. Michelin says min temp for storage is 50F for storage and 59F for transport. My question is, what are people doing on track days with temps below 50 such as this upcoming weekend at Summit? Thanks
Jeff
Jeff
Hi Folks,
Jeff
Jeff
Two options: swap to street tires or buy some tire warmers. We ran a race on MPSCs when it was 30-45 F and they were fine.
the 3rd option is to stay home.
Jeff
I ran Michelin slicks on my CS several years ago during the morning warm up and 1st stint at the March Chin event at NJMP. Temperatures were in the low 30's (but above freezing). There was "zero" grip for 3-4 laps tip toeing around to get heat in the tires. Nearly had the back end swap places with the front before turn 2 when first entering the track. I switched to a set of street tires after that for the rest of the event. I won't go out on slicks again unless temps are 40 or above. Too risky.
Couple of my buds running Hoosiers called it quits midway through day one because of the cold and lack of grip.
thuggo (03-04-2021)
