recommendations for towing vehicle
Any recommendations for a good towing vehicle for GT3 and aluminum trailer that you also think makes a reasonable daily driver? Looking at a Tundra or Titan. Currently have an Xterra, but I think the load is stressing out the engine. thanks
Thank you, I have used it, and other than sparse references, no tangible information to answer my question. Any other good suggestions other than an imotican?
Search function
06 Cayenne ****
89 944S2 #700
06 GS 300 DD
07 JAG XK
My next street car shall be a 997; you should they are nice
Search function
06 Cayenne ****
89 944S2 #700
06 GS 300 DD
07 JAG XK
I tow a similar rig w/ a V8 gen 4 4Runner w/ factory tow package rated for 7.3k#
any of the 1/2 or 3/4 ton V8 pickups & a few 6 cyl would be fine, there's a lot to be said for 1/2 to 3/4 ton vans too as long as they aren't going to be daily drivers.
check on the manufacturer web sites for tow ratings, a factory tow package is a big plus
I have an '01 Tundra Extra Cab V8. I have pulled my 996 on a not so lightweight car trailer and it tows well. Depending on the year, you need to be aware that some of the Tundras had tranny problems. I had to rebuild mine as the overdrive gear grenaded the transmission (and it was before I seriously towed anything).
I've known no one that every stopped at an open trailer. You will accumulate extra parts and extra wheels/tires and will need an enclosed trailer.
Toyota and Dodge both option a 4.7 liter V8. Toyota tunes theirs for 290hp and 230tq, Dodge went 230hp and 290tq.[+] Recommend that you get a Factory Tow Package as that includes bigger four wheel Disc Brakes, additional cooling for the Transmission, better gear ratio Diffs, wider Mirrors, and the 7 pin trailer plug with conversion adapters. 4wd is also a nice add-on when it absolutely, positively, must get there. Dodge Dakota is the only 'normal' size pick-up that has a V8 nowdays. Club/Extra Cab models will haul four Adults with ease. 4 Door models are the best sellers in the line-ups. Tow ratings are around 6500lbs.
