BAD ENGINES PROBLEM - PLEASE READ
TO WHOM IT MAY CONCERN,
IF YOU HAVE A WATER COOLED ENGINE AND HAVE HAD YOUR ENGINE REPLACED PLEASE TELL ME THE STORY.
IF YOU HAVE MAJOR OIL LEAK PROBLEMS THAT HAVE CAUSED YOU TO HAVE THE ENGINE REPLACED PLEASE TELL ME.
PORSCHE HAS MAJOR PROBLEMS WITH THE BOXTER ENGINE AND IN THE 996 1999, 2000,01,02,AND 03 MAJOR ENGINE PROBLEMS.
I WILL LET YOU LISTEN TO A RECORDED TAPE OF A FACTORY REP TELLING ALL THE PROBLEMS WITH THE ENGINES.
JUST IN CASE YOU DID NOT KNOW PORSCHES WARRANTY POLICY WHEN THEY DO REPLACE AN ENGINE THAT IS STILL UNDER WARRANTY THEN LISTEN UP:
I WANT YOU TO HEAR IT HERE FIRST.
AS PORSCHE HAS A MAJOR PROBLEM WITH THERE WATER COOLED ENGINE AND IN THE EVENT YOU ARE A LUCKY ONE THAT STILL HAS A WARRANTY LEFT AS THE ENGINE NEEDS TO BE REPLACED AS IT HAS FAILED.
WELL THIS IS HOW THEY COVER THE DEFECTIVE ENGINE, IF YOU HAVE ONLY ONE MONTH LEFT ON THE ORIGINAL 4 YEAR WARRANTY THEY WILL ONLY COVER THAT NEW REPLACEMENT ENGINE FOR 1 MONTH ONLY.
NOW IF YOU BUY A NEW ENGINE OVER THE COUNTER THEY WILL COVER IT FOR 2 YEARS. ITS A TOTAL RIP OFF FOR ALL OF US.
GOOD LUCK WHAT EVER YOU DO BUT IT WOULD BE FUN TO HEAR FROM ALL OF YOU.
OH BY THE WAY THE 2003 HAS NOW MAJOR OIL LEAKS WHICH NEEDS FULL ENGINE REPLACEMENT.
THINK SMART BEFORE YOU GET TAKEN ADVANTAGE OF
