wet floorboard??? Cayenne
I cleaned evaporator drain out seemed fine. Both floorboards are wet on both sides this is the 3 rd cayenne Ive seen do this. Anyone else have this problem?
Frame rail plugs prior to this problem.
Casey
Casey
I have a 2008 GTS and noticed some moisture on the driver's side only once. Then after a very hard rain, the electrical system began getting Gremlins and the source was water running into the driver's side A pillar. Not sure if that side is where you are seeing water, but mine wasn't the first one with this problem.
Brad
Brad
