Lost it in a 991 4s
Hey Guys,
Looking for a little driving advice. I was pushing my C4S today at about 35-40mph around a flat onramp. I let off the gas early/mid intrry (probably the wrong thing to do) and lost the backend, stepped off the gas and the front end corrected and saved me from spinning out. Is this normal? All 4 tires were rubbing/sliding when the computer kicked in and corrected. I'm well aware of the old 911's/930s backends going out with the oversteer issues, etc., but I thought this behavior was corrected a few moons ago... Any suggestions on how to engage/disengage and avoid the rails going forward?
Much appreciated,
Nate
Much appreciated,
Nate
Hey Guys,
Much appreciated,
Nate
Much appreciated,
Nate
First mistake, you went into the corner too fast. You should gain speed in a corner, not loose speed. Hit the brakes before the corner (when you are stiil going in a straight line) and then carefully get on the throttle when you enter the corner and slowly increase your speed.
Second mistake never go off the throttle mid-corner. Your Porsche can probably do more than you expect/dare, and as long as you keep feeding power to the tires to pull you through, you have a better chance of saving your butt. Especially when it is wet. The electronics will moderate power so you cannot overdo it. But better take it slower next time and only start building up more cornering speed once you get more comfortable and experienced. Even better, take a course for high speed driving. You will learn basic skills and perhaps even trail braking which will keep your car and you in one piece.
Always buy the best tires you can afford (change to winter tires in a cold climate) and if your tires are old, replace them! Old tires with enough tread still killed Paul Walker.
To some extent, the classic 911 rules still apply. Once you find your speed too high in a corner, your only choice is whether to hit the wall nose first or a** first.
