Looking for a Porsche Mechanic in N. VA, Play in front wheels
Hi,
I own a 1983 944. I just moved to Fairfax, VA. Now, I need to find a Porsche mechanic. Does anybody know a good one?
My car failed the VA safety inspection because of play in the front wheels. I knew this existed. In June I bought new tires for the car, they also told me that there was play in the front wheels. I checked the joints myself, replaced the tie-rod boots, and adjusted the tightness of the wheel bearings. Everything seemed to be O.K. Then I took the car to the alignment shop and had it aligned. He told me everything lined-up properly; no problems. The car drives great. There is no play in the steering or vibration at any speed. But, it still does not pass VA inspection. I'm going to have it checked at a Porsche shop.
I'd like to know if it is typical for a 944 to have more wheel play than other cars? I heard of 944s having mysterious front wheel shimmy. If anyone can elaborate on this I would appreciate it.
Thanks,
SB
Thanks,
SB
cheack out Autobahn Service Inc Fairfax Porsce Specailists VA 703-691-1771, I live right out side vienna its about a 10minut drive to them, they are near fairfax high school. they do very good work never had any problems with them also all work is garenteed for 4000miles
Hi welcome to the area, here is our local forum www.dorkiphus.com, there are alot of people in NoVA on this forum that can help you out. Personally, I would check out RPM in NoVa.
