Was curious if there is anyone in the DC area that has a manometer in order to perform an AOS test on my 996.2. I'm seeing oil consumption and an occasional white smoke puff at start up and would like to confirm it's the AOS before dropping coin on a UAOS set up.
Bump 4 u. I can do it but probably too far away in north de.
skip can get u the diagnosic cap and meter for not that much $ and u can test it yourself.
Thanks and I did consider buying one. If you're in north DE then it may actually work for me as my parents live right outside of Philadelphia in Delaware County which is not far from DE at all. I could potentially make a stop when I go visit next. Will PM you when that happens and thanks for the offer!
Fantastic. I'll be installing it into a mk2 but look forward to seeing what it all looks like. I'll PM you when I'm making the drive over to PA. Thanks!
