FS: Sim Racing Next Level Racing F-GT Cockpit, PC, Monitor and Monitor Stand
Cross post from: https://rennlist.com/forums/market/1296446
My old sim racing cockpit/rig is now for sale. Upgraded to an aluminum chassis with a direct-drive wheel base and hydraulic pedals. Includes gaming PC with the NLR monitor stand and a 34” ultra-wide Alienware monitor. This is a turn-key sim racing cockpit that's ready to go! Save time by not having to assemble, tune, adjust and install anything. Windows 10, device drivers and iRacing and Assetto Corsa Competizione pre-Installed. Just login with your account, set your preferences and go racing!
- Fully built and ready to race Next Level Racing F-GT cockpit frame in GT mode with lockable caster wheels, supports up to 285lbs.
- Pre-installed NLR strengthening kit for the pedals and wheel plate
- Monoka Racing Bucket seat with sliders and brackets
- Thrustmaster T300RS Wheel Base and Stock Wheel
- Quick-Change Wheel Ring Lock (no need to use a screwdriver to change wheels)
- Thrustmaster T-LCM Load-Cell Pedals with upgraded brake elastomers for increased stiffness (includes factory two-pedal set that came with the T300RS)
- Thrustmaster TH8A Shifter with upgraded internals for improved tactile feedback
- Practically brand-new Sparco R383 wheel upgraded with magnetic shifters
- NLR Monitor Stand (includes VESA mounts for large format monitors/TVs)
- Alienware AW3418DW 34” Ultra-wide Monitor
- Corsair Wired 5.1 Headset
Gaming PC Specs:
Case: Lian Li LANCOOL 205 Mid-Tower Chassis ATX (new)
PSU: EVGA 750W Bronze Power Supply (new)
Motherboard: MSI MAG B550 Tomahawk (new; updated with the latest BIOS firmware as of 09/18/2021)
CPU: AMD Ryzen 9 3900X (bought in early 2020)
CPU Cooler: AMD Wraith Prism RGB Cooler (essentially new since I never used it until this rebuild because I used a liquid AIO cooler with the 3900X)
RAM: 32GB (4x8GB) Corsair DDR4 3600MHz Memory (new)
GPU: 11GB EVGA GTX 1080ti SC2
Storage:
- 512GB Seagate Firecuda 510 NVMe SSD (OS Drive) (bought in early 2020)
- 2TB Seagate SATA 7200RPM Drive (Data/Game Drive) (new)
- Windows 10, Drivers and iRacing and Assetto Corsa Competizione pre-Installed.
Chassis Fans: 5 x 120mm PWM Arctic Cooling Fans (new)
Includes:
1. Used CoolerMaster MK730 TKL (Ten Keyless) RGB Mechanical Gaming Keyboard with Cherry MX Blue Switches (includes black key caps and key cap puller)
2. Used Razer DeathAdder Elite Wired Gaming Mouse
3. Wireless Logitech Keyboard/Trackpad
Asking $2400
Gaming PC Specs:
Storage:
Includes:
Asking $2400
