P12a2 code
Background: I went thru the forums and replaced the oil sep, and also found out the hoses were cracked so I replaced them. Code cleared ran fine.
fine. Mpg was at 18-19.
Currently the code just reappeared 😱 CEL comes on hangs around then goes out. Ran a scan and it's not pending anymore it's a fault. Mpg is down to 12! She still runs fine though? Anyway to tell if the fuel pressure sensor is shot? Or any suggestions on what I should check next? This code sucks 😆 it lingers!
