'Check Dipped Beam' Issues/Fixes - Cayenne
I have a 2008 Cayenne S. Had condensation in the left headlight assembly after brutal cold spell last winter. Applied Silicone gel to seals, dried out unit gently with heat.
My driver's side low-beam headlight does not work (Xenon HID). THe cornering light works sporadically/does not work.
High beam is Fine, as is turn signal and lower fog lights. Issue is that I have to have both headlights working to pass inspection in my state (rapidly coming due), and my regular mechanic can not fix this problem. Took it to the dealer, who quoted me an astronomical price that made it so I am seriously considering trading the car, which would be a shame.
My question: the fix detailed in this post doesn't seem applicable- I have a really good fit plugging the harness into the headlight assembly. Also, can I conclude that the High Beam ALWAYS working correctly would indicate it is something else besides the wiring connection?
What steps should / could I take myself to investigate this that are cost effective, and in what order? I mean, after changing the bulb, checking the connection pins, electrical cleaner, and this trimming of the plastic fix? I do see that some of the wiring inside the headlight assembly has some insulation flaking off and the copper wire is exposed...
Should I get a new harness? Ballast? A whole new (used) headlight assembly? Other??
Any guidance from those with experience with these issues would be appreciated...
delauren667 (04-16-2024)
