Engine Variable Timing Solenoid
Recently received misfire codes P0300, P0301, P0302, and P0303 and also P1382 code on my C2 991.1 7MT . It runs a little rough at idle but no other issues past 2K RPMs and does not have a stumble issue. Other threads mention to look at the Engine Variable Timing Solenoid. Does anyone have a pic of the location of this or schematic of this that can be shared? There is no info on this part. Replacement part # 9A110530803 - 9A1-105-308-03
