Axles
I have been researching for about two months now and I can't seem to find any outer CV joints for the front axles for a 1999 911 C4. I can barely find the full axle assemblies. I was wondering if anyone could help me out. If there aren't any places that make just the outer CV joint and I do have to replace the entire axle, can I use a "rear" axle up front or are they truly different axles? It the pictures they seem to be exactly the same so I'm not real sure. Also, I've never worked on a porsche before (just about everything else) and so any and all additional guidance on the front, outer CV joint/axle would be greatly appreciated. I can also be emailed at scottmcallister03@gmail.com. Thank you so much.
Scotty,
not to be an *** but did you try post this on the 996 Forum?
https://rennlist.com/forums/996-forum-60/
