Transmission oil change DIY
Quick facts
Req. Change Frequency: every 48,000 miles (min)
Oil (qty): 75 W 90 gear oil (3.8 qts)
Fill and Drain plug Torques: 22 ft-lbs.
Fill and Drain Plug Hex wrench size: 10mm.
Replacement parts: 2 aluminum seals (Porsche p/n 900-123-011-30; “Sealing ring A 22 x 27”, Pelican p/n 900-123-118-30-M131)
Tip: This is the same seal used on both engine oil drain plugs. Since they’re inexpensive [@ $0.50], it’s convenient to buy extras for upcoming oil changes, as well.
Steps:
1. Driving car just prior to this procedure to thoroughly mix the transmission’s oil is preferred.
Overview of procedure items to be used: Fig 11.
[The short piece of plumbing pipe shown was needed in my case to help break loose a (previous) overzealously torqued plug.]
![Name: Fig 11Transmission fluid change supplies used in demonstration.jpg
Size: 129.4 KB](https://rennlist.com/forums/attachments/diy-964-1989-1994-911/356092d1241182685-transmission-oil-change-diy-fig-11transmission-fluid-change-supplies-used-in-demonstration.jpg)
2. Jack up car at the left/driver’s side, rear jacking point. [Fig 1] Remove left rear wheel.
![Name: Fig 1 Driver's side rear jack (with safety stand).jpg
Size: 100.3 KB](https://rennlist.com/forums/attachments/diy-964-1989-1994-911/356082d1241182623-transmission-oil-change-diy-fig-1-driver-s-side-rear-jack-with-safety-stand-.jpg)
3. Place catch pan under transmission drain plug. (Expect 1 gallon of fluid to drain fast.)
4. Remove transmission fill and drain plugs w/ 10mm hex. [Fig 2]
Note: Jaime reminds me of his frustration of removing the drain plug 1st, only to find the fill plug impossibly torqued tight.
(How would you refill that scenario?)
Lesson learned: Remove the fill plug 1st, for sanity's sake.
![Name: Fig 2 Overall arrangement.jpg
Size: 99.1 KB](https://rennlist.com/forums/attachments/diy-964-1989-1994-911/356083d1241182623-transmission-oil-change-diy-fig-2-overall-arrangement.jpg)
5. Lower car to (level to) complete transmission draining.
6. Inspect and remove metal debris from drain plug magnet. [Fig 3, 4, 5, 6]
Note: Metal shavings shown in Fig 3 are normal. If metal chunks are present, seek professional review of your transmission.
![Name: Fig 3 Drain Plug Removed.jpg
Size: 41.5 KB](https://rennlist.com/forums/attachments/diy-964-1989-1994-911/356084d1241182623-transmission-oil-change-diy-fig-3-drain-plug-removed.jpg)
![Name: Fig 4 Drain Plug cleaned with old & new seals.jpg
Size: 49.5 KB](https://rennlist.com/forums/attachments/diy-964-1989-1994-911/356085d1241182623-transmission-oil-change-diy-fig-4-drain-plug-cleaned-with-old-and-new-seals.jpg)
![Name: Fig 5 Fill and Drain Plugs.jpg
Size: 61.4 KB](https://rennlist.com/forums/attachments/diy-964-1989-1994-911/356086d1241182623-transmission-oil-change-diy-fig-5-fill-and-drain-plugs.jpg)
![Name: Fig 6 Hex Tool 10mm.jpg
Size: 63.4 KB](https://rennlist.com/forums/attachments/diy-964-1989-1994-911/356087d1241182670-transmission-oil-change-diy-fig-6-hex-tool-10mm.jpg)
7. Jack up car at the left/driver’s side, rear jacking point.
8. Reinstall cleaned drain plug to 22 ft-lbs. [Fig 7, 8]
![Name: Fig 7 Prior to final draining (off the jack).jpg
Size: 99.1 KB](https://rennlist.com/forums/attachments/diy-964-1989-1994-911/356088d1241182670-transmission-oil-change-diy-fig-7-prior-to-final-draining-off-the-jack-.jpg)
![Name: Fig 8 Reinstalling Drain Plug.jpg
Size: 76.7 KB](https://rennlist.com/forums/attachments/diy-964-1989-1994-911/356089d1241182670-transmission-oil-change-diy-fig-8-reinstalling-drain-plug.jpg)
9. Fill new transmission oil into the transmission fill port until fill port overflows. [Fig 9, 10]
Note: I used a gravity feed to fill the tranny by holding the oil bottle shown above the transmission's level (and punching a hole in the oil bottle) the oil will flow into the tranny. Sure, it's a little slow, but it's a 'no' pressure, works-every-time method I found convenient. There are other oil pumping devices you may choose to use. Many ways 'to skin this cat.'
![Name: Fig 9 Filling to overflow (note drip in mid-air).jpg
Size: 61.4 KB](https://rennlist.com/forums/attachments/diy-964-1989-1994-911/356090d1241182670-transmission-oil-change-diy-fig-9-filling-to-overflow-note-drip-in-mid-air-.jpg)
![Name: Fig 10 Overflow draining overview.jpg
Size: 102.6 KB](https://rennlist.com/forums/attachments/diy-964-1989-1994-911/356091d1241182670-transmission-oil-change-diy-fig-10-overflow-draining-overview.jpg)
10. Lower car to (level to) allow further overflow of transmission oil. When flow has decreased, jack the car back up.
11. Reinstall cleaned fill plug to 22 ft-lbs.
Transmission oil change complete
Quick facts
Steps:
Professor of Pending Projects
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
This is grea! Thank you!
The only thing I would add is
MAKE SURE YOU CAN REMOVE THE FILL PLUG BEFORE YOU REMOVE THE DRAIN PLUG...
There was this time, with my 951... anyway... you get the idea...
