How to clean ISV, and air-flow meter
I had a problem with a poor idle recently. With thanks to John B, Adrian and Taj I finally got around to cleaning the bits detailed above and thought this might be of use to anyone with a simple idle problem.
First off I removed the right side of the airbox, with filter. There are 4 clips, two front and two back. The clips should be fixed (fronts to the right side of the airbox, rears to the left) but my airbox was battered and the clips not held on. My rear lower was nowhere to be found, which in itself could apparently have caused the dodgy idle. A second-hand airbox cost me £60 and the filter is held squarely now and the clips don't disappear.
With the filter and half airbox out you will see this:
![](http://forums.rennlist.com/upload/4nuts.jpg)
Remove the 4 nuts securing the left side of the airbox to the air-flow meter. It is much easier to get the 2 nuts out behind the plastic tube after you have levered the plastic tube out
Be aware there is a gasket between the airbox and the air-flow meter. Chances are it will remain stuck to the airbox. As Jason kindly points out later in this thread Porsche recommend changing this gasket - 928.110.201.01. Another of Jason's tips is to not separate the airbox from the AFM at all; you can clean the AFM while it is still attached to the airbox, just out of the car.
If you want to remove the airbox completely there is a nut at the bottom of the airbox shown here and the last nut (and washer) to remove is the obvious silver one holding the left side of the airbox down at the front. Once I'd loosened mine it threatened to spring off presumably because of the rubber damping below it. Hold it firm! All 6 bolts that get released use a 10mm socket. Finally there are two hoses attached to the left side of the airbox; a small one that enters about level with the top of the vacuum reservoir (visible in a picture below) and a larger hose low down into the back of the airbox, also visible in Jason's picture, just above the lower clip on the right hand side. Both twist off and are far easier to get off than back on.... A little contortion is required.
The following 2 users liked this post by DavidI:
nabfa1 (12-30-2023),
TheAbeFroman (09-30-2021)
With the 4 bolts out from the right hand side of the air-flow meter you need to free the left hand side, by slackening the jubilee clip pretty much in the centre of this picture that holds the large-diameter hose onto the air-flow meter. Note! There is another jubilee clip in the picture, on a smaller hose, more toward the top left of the picture. Please only loosen the correct clip!!
![](http://forums.rennlist.com/upload/airnut.jpg)
With the clip loose you can easily work the air-flow meter away from the hose and it slides towards you quite easily. There is a clip attached to the back of the meter which needs to be removed, so do not try to take the meter out completely; to release the clip press down on the long edge of the metal retainer and the sides will splay outward and the clip can be withdrawn. Note there are 3 clips like this that can be released and cleaned, one on the meter (5 connecting pins) one on the ISV (2 connecting pins) and one below the ISV (3 pins). They cannot be interchanged so I didn't bother labelling them!
![](http://forums.rennlist.com/upload/3clips.jpg)
Here's the hose that was connected to the air-flow meter. This picture shows the jubilee clip that needs to be undone much clearer than the one with the meter in place:
![](http://forums.rennlist.com/upload/airfout.jpg)
It's also easy to see where the other two connectors were plugged into, on the ISV and just underneath it.
Here's the space left by the air-flow meter showing the vacuum reservoir that is normally hidden, and the gasket (928.110.201.01) mentioned earlier. Note the thin pipe mentioned earlier going into the reservoir. This needs to be removed if you intend taking out the left side of the airbox.
![](http://forums.rennlist.com/upload/gasket.jpg)
nabfa1 (12-30-2023)
Next up comes releasing the ISV. You can see in the picture 2 above the jubilee clip that goes around the ISV and holds it to a brass-coloured frame (I've removed it when taking the picture below) - it's easier to see the frame on not the next picture, but the one below that. I removed the jubilee clip first but you could loosen it and leave it in place to stop the ISV moving while releasing the crimp clamps holding the hoses to either side of the ISV. You will need to replace these clips, they are part number 999 512 380 02. I bought replacement jubilee clips too but didn't use them, 999 512 499 00. The crimp clips can be cut off, or loosened by working a flat bladed screwdriver into the piece that is crimped and gently widening it. I did this while holding the hoses still to not put any pressure on the hoses.
![](http://forums.rennlist.com/upload/isvcons.jpg)
Here's the space vacated by the ISV, showing the plate that the ISV sits on and that the jubilee clip goes around. Note one side of the ISV is longer than the other; the far side hose comes off very easily, the near side takes a bit more effort.
![](http://forums.rennlist.com/upload/isvout.jpg)
The idle microswitch is the black rectangle with the cable running to it under the long spring;
![](http://forums.rennlist.com/upload/idlems.jpg)
If you press on the bit my finger is on, it opens, like this:
![](http://forums.rennlist.com/upload/idleopen.jpg)
I gave a quick spray with carb cleaner and wiped both sides down to make sparkly clean - they were very grubby.
nabfa1 (12-30-2023)
nabfa1 (12-30-2023)
