88 transmission protection switch leak,... FIX
Old Dec 14, 2021 | 08:22 PM
Rexxus's Avatar
Rexxus
Default Updates
Originally Posted by GregBBRD
I'm going to guess that the difficult part will be getting the existing threads straightened out.
And them being the "ever common" 27 x 1.5mm threads means some hunting to find a shop with that tap.
Maybe you can grind a notch in the broken switch and use it a thread chaser?
You should be able to grab the "barrel" with a pair of "broad nose" pliers...that's how I get them out.
And then you need a switch.
I managed to get the barrel out. PHEW!!! I tried pliers but I guess mine were either too big? I used a tiny screw driver to test and make sure I could move the metal tab side to side. Check. I grabbed a piece of thin wire and made a loop and looped it over the tab. Came out no prob. I’ve posted some pics below of the switch which is obviously garbage but more so to show the threads. I’ve also posted the best pics I can of the trans threads. What do you think?
I tried to hand tighten the switch into the hole after I got the barrel out just to see. If goes in to exactly the same place so I’m not too sure it’s damaged. Seems like no difference from the first time. Anyone else have issues screwing In the switch? With no barrel it should go right in right? Any thoughts on the condition of the threads and why this bugger won’t screw in?
oops forgot the pics. When I took the switch out initially without problems I stuffed a rag into the hole to prevent debris from getting in as I opened and closed the garage door. The next day the rag was a little damp. Is there any way the barrel could have damaged the hole causing a leak? As you can see there’s ATF in the pic. You guys also mentioned the size of the transmission hole. That’s standard on all 928’s / an 89? 27 x 1.5mm threads?
I tired my best to show the threads. Not sure if that’s helpful but thanks again for following the saga of the switch!
Old Dec 14, 2021 | 09:51 PM
GregBBRD's Avatar
GregBBRD
Former Vendor
Yeah, those threads are not very "pretty".
Since there is no seal or O-ring on that switch and there is that deep rectangular cut through the threads (leaving a very narrow sealing surface), it has to sit perfectly square to the threads, in order to seal.
Which means the threads have to be good enough to make sure the switch is perpendicular.
And once you've put a wrench onto cross threaded threads, they are not particularly easy to straighten back out.
The good news is that there's a whole bunch of "smarts" on this forum, who excel in figuring out how to fix messed up things, on the cheap.
Someone will have a genius idea!
Old Dec 15, 2021 | 12:01 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
I like Greg's idea to use the old part to chase the threads,
I would cut 3 even slots into the old broken switch,
you can line the cuts with 3 alternating flats where the wrench would fit.
I use the side edge of the grinding wheel;
cut in about 2 to 3 threads about 3 MM deep, this will act like a tap, put grease on the threads to catch any shavings .
Dont force anything and you might have to remove the rear half of exhaust system and heat shields to get a better perspective.
Based on what your reporting,
you put the switch into the trans at an angle and continued to force it in this snapped off the tip and cross threaded the switch bore
\ what part of the instructions do you think you did not follow?
Maybe I need to add more info to the install procedure so this doesn't happen again.
I think I made a warning to not force anything,
everything with this assembly should fit easily.
are you working on a lift or on jack stands?
maybe the car is not high enough off the floor?
Old Dec 15, 2021 | 12:16 AM
Rexxus's Avatar
Rexxus
Default Oh mama!
Hopefully removing the exhaust won’t be necessary because I’ll have to take the car in to a mech to fix so my $80 project is gonna be a $1500 project. Where’s the head smash emoji?
you’re too kind amending your instructions lol. I’m new and thought this would be an easier fix. I broke a cardinal rule and forced something and will have to pay for the mistake.
for what it’s worth though here are my thoughts on the instructions;
- more detail on what the seated barrel looks like. Maybe a picture. I couldn’t really tell so I used my mirror to try and see if the tab on the barrel was flush with the transmission hole. Seemed like it was
- then add a sentence that explains you should be able to hand tighten the switch to whatever. Flush? An 1/8 of an inch from the bore?
- I guess add a warning not to be a **** and tighten a crooked switch
I actually backed the car up on wedges so I’d have more space. I have jack stands but they weren’t high enough for me to be able to work well. So wedges… I can’t imagine that created the issue though because I was able to loosen the switch no prob
Old Dec 15, 2021 | 02:55 AM
Rexxus's Avatar
Rexxus
Default So I can sleep better
so like have I blown up the car? Is this the type of thing where if the mechanic cannot re-thread the car is scrap???? Or is my absolute worst case scenario that I need a new transmission which is what I’m assuming this switch screws into? And if that’s the case so I have a $10,000 with $20,000 into it type thing?
could you elaborate on the tap dimensions? So id be looking for a 27mm tap with thread spacing of 1.55m? So when you search for taps, I search for 27mm first and then comb through for 1.55mm spacing? My mechanic said he can machine the needed parts so hopefully he knows the tighter spacing he’s into.
if he machines the tap, do you think there’s any interest in the community for me to buy it and share it if needed? Or is the bore hole like the only one of its size on the car?
lastly, given your comment about how the seal has to be perfect, does it make sense in general whenever anyone does this maintenance to put thread locker?
