AIM Smarty Cam gauges flicker
I have updated the firmware, still buggy BTW. However, when I got to review my data the gauges flicker and the brake pressure doesn't work. I've replaced the brake pressure sensor and that fixed the issue within the RS3 software, but still doesn't work on the SmartyCam. All connections are tight and no loose wires. Any suggestions?
Rennlist Hoonigan
which cost no drachmas
Make sure the CAN output (last tab in the setup) for the dash shows the correct channel for brake pressure. Then make sure in the SCHD setup that it is set for brake pressure with an appropriate max pressure. That is normally the problem areas.
