Any examples of a string pot to measure stearing angle on 996 GT3?
Old 05-03-2017 | 11:54 PM
rbahr's Avatar
rbahr
Default Any examples of a string pot to measure stearing angle on 996 GT3?
Best place to mount it?
Ray
Old 05-05-2017 | 02:39 PM
rbahr's Avatar
rbahr
Anyone?
Old 05-05-2017 | 02:53 PM
ProCoach's Avatar
ProCoach
Basic Site Sponsor
From: Durham, NC and Virginia International Raceway
I recommend around the column. Sorry about the big pic. Current string pots feature a metal wire rather than plastic.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Old 05-05-2017 | 03:34 PM
rbahr's Avatar
rbahr
I wanted to keep the wire either before the 1st knuckle or after the second due to non-linearity's...
Ray
Old 05-05-2017 | 03:50 PM
Matt Romanowski's Avatar
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
I can probably get you a pick from a Cup next week. I have non Cup pictures that look like Peter's.
For the nonlinearity, you should be able to make a custom sensor that will fit the curve. Just take more points instead of the normal 3. If you search, Winders had to do the same thing.
Old 05-05-2017 | 04:34 PM
rbahr's Avatar
rbahr
Thanks Matt,
Since I don't have a cup, perhaps some of those pictures would be good. I actually still have the rug down - I am in complete denial of that I may already be somewhat down that racer car slope :-)
Will you be at 48hours?
Ray
Old 05-05-2017 | 04:38 PM
Matt Romanowski
Rennlist Hoonigan
Originally Posted by rbahr
Thanks Matt,
Ray
I'll be at the 48 Hrs and Cups and Saucers next week.
Old 05-05-2017 | 04:41 PM
rbahr's Avatar
rbahr
Don't have time for C&S, car still in many bits & pieces, will be at 48 hours and would like to have this sensor, and perhaps brake & accel. in...
Ray
Old 05-05-2017 | 09:24 PM
38D's Avatar
38D
That pict is Geoffrey Ring's 964 Motec monster. Not sure that a 997 steering column is the same.
Old 05-05-2017 | 10:01 PM
Matt Romanowski
Rennlist Hoonigan
The 996 and 997 is very different. Here is my 914 photo that I took.
Old 05-05-2017 | 10:26 PM
ProCoach's Avatar
ProCoach
Basic Site Sponsor
Just an example. Not for a specific car. As Matt's example shows, this is a very simple and common way to mount this type of sensor and collect this information.
Old 05-06-2017 | 12:38 AM
winders's Avatar
winders
If you can't put the string pot before the first universal joint or after the last one, read this thread:
https://rennlist.com/forums/data-acq...iguration.html
Old 05-08-2017 | 03:17 PM
rbahr's Avatar
rbahr
Thanks Scott!
Ray
Old 05-08-2017 | 03:23 PM
winders's Avatar
winders
Thanks Scott!
You're welcome, Ray!
Old 02-16-2021 | 10:51 AM
zbomb's Avatar
zbomb
I found this searching for the answer to the same question in the OP.
Not a lot of options on the 996, here is how mine is mounted - I have some finalizing to do but this should give folks interested in an install location an option.
I will be using Winders cal method he kindly linked to.
Quick Reply: Any examples of a string pot to measure stearing angle on 996 GT3?
