Multi-Channel Infrared Tire Temp Data Processing
Forgive me if this is not an appropriate place for this discussion. Most of my searches on this topic end up with hits on this forum so there seems to be lots of knowledge here. I am the DAQ lead for the University of New Mexico FSAE team seeking some information on displaying data from multi channel infrared tire temperature sensors.
I have been looking at the Motec dash loggers and really like them but we all know the costs are very high, especially if you factor in pro data logging.
I know I2 pro can display color contour maps as shown below, no problem.
I have also been looking at the AIM MXL2 as it has a very strong feature set, math channels, the whole bit, EXCEPT the ability to generate these contour maps of each temperature channel side by side. Unless I am mistaken this cannot be done in Race Studio 3. Is this correct?
The sensor is going to be placed either on our front wing, inside the side pods, or on the chassis for the front wheels so it will see the tires turning and flexing and I would like to create an image of the tire temp profile since the sensor will never be in perfect alignment.
As I understand it I can output a data file into matlab and use a script to create these plots. I am unsure how much pre processing this would require and I would like this data trackside ASAP for turning suspension and alignment. Any ideas on how to do this quickly?
I am kind of stuck here. I don't know that the Motec is worth triple the price to generate just this one type of plot.
Does anybody have experience with this type of sensor?
Can GEMS create this kind of data? Can AIM output easily to GEMS?
An example of a Matlab output and a F1 car below:
Thanks so much for your time and apologies if the non-Porsche content is unwelcome.
Rennlist Hoonigan
which cost no drachmas
If you want wants some AiM files to work with I can supply them. I can also offer a FSAE discount to you and I sell AiM products and can help you with Texsense IR sensors.
Feel free to email me at matt@trailbrake.net if you would like the files.
Thanks for the info Matt.
I have been looking at the 16-channel Izzy Racing CAN sensors. He offers it at less than the 4 channel for FSAE. It looks pretty similar to the Texsense IRN8. I can ask you about costs offline. Either would work and the idea is to just make an "image" of the tire. You can see in the matlab generated image I posted that the tire is very visible even as it moves around.
The main goals are to see what peak temperatures the car is seeing, and how quickly it gets there. Then seeing what the gradient is to help us tune and verify alignment, corner weights, etc.
Our team has not been awesome with closing the design loop and test and tune in past years.
Anybody have experience with the GEMS software and how it compares to RS and I2?
Basic Site Sponsor
Basic Site Sponsor
From: Durham, NC and Virginia International Raceway
I think the Izze Racing triple-in-one are the way to go. Use the 2nd CAN on an MXL2 and the Texense template and you're good to go. Each corner is a third the cost of the strips.
I have not had good luck with the GEMS software. I2 is the standard, RSA is 85-90% if your template requirement is supplied (you can make much more customizable, but not necessarily more useful for YOUR application, worksheets in i2 Pro).
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Holy *****. I didn't know the Texense was so much more expensive. $300 for the 16 channel Izzy sensors seems like a bargain.
We are still in are initial design review phase, It's possible we go with the Motec, but I don't think they offer as much discount to FSAE besides being just plain more expensive. It should be a good investment for design report points as well as tuning for the dynamic events. It can also be passed down to other teams with only the purchase of new wiring harness and sensors.
Basic Site Sponsor
Basic Site Sponsor
Strips typically $1080/corner, Izze $399/corner.
I have supplied other FSAE teams with a MoTeC C125 with logging memory and with Pro Logging enabled. I believe the discount is 10%. There also may be a possibility you could use a CDL3 kit with Pro Logging enabled and end up spending not a whole lot more than a MXL2 and get the info you're looking for very easily, so don't blow off MoTeC yet...
Yeah I am just trying to present the best couple options and then the team can decide which one we go with and I will figure out how to integrate it as best as possible.
So far we are planning on doing the tire temp sensors x 4 (CAN), steering position, shock position x 4, brake position, wheel speed x 4(3? C125 only has 3 inputs which makes no sense), and then pulling the rest from the Motec ECU.
I have not looked into trying to get wheel loads from strain gauge/amp's but if we can integrate it for not a huge amount of money I would need inputs for that too. This may limit the use of the CDL3.
Rennlist Hoonigan
Pierre at Texsense has worked with lots of FSAE teams and offers a discount, though I don't know how much.
If you are good at MatLab, I think you will end up doing analysis there inbetween sessions.
Basic Site Sponsor
Basic Site Sponsor
The new systems all seem to have GPS for speed and internal lat/long acceleration, which means you'd only look at wheel speed to detect wheelspin or brake lockup, and not need to worry about tire diameter and changes due to pressure or wear.
One thing I have seen for belt-driven water pumps is an RPM sensor on the water pump to detect when the belt comes off and sound an alarm before the water temp skyrockets.
Sounds like a great project, Good luck!
I will look into the brake pressure transducers, that could be useful to verify the braking forces on the calipers and adjust the bias bar.
I am pretty sure I am going to try and include something like these Transducer Techniques Load cells that I can put inline on the push/pull rods to get wheel loads as well.
Typically in a race car I see brake pressure x2 (front and rear circuits) since it's pretty easy to tap into and you don't have to worry about slack in the pedal travel and get the bonus of seeing balance as a math channel (which you can display real-time in an MXL2 dash, BTW).
Hi,
You may want to look at: http://www.melexis.com/Infrared-Ther...90614-615.aspx
and just build up something...
Ray
Ray
Hi Matt,
The emissivity is user programmed into the device, or you can apply the corrections post collection. Device is itself temp compensated, and cheap!
BTW a fairly inexpensive brake pressure transducer is the BMW part used in their ABS systems... All this data can be gathered by something like a Raspberry PI, coupled with a GPS time stamp and then combined with all the other data...
Ray
Ray
