AIM Evo4 modifying tracks
Old 11-30-2015 | 05:32 AM
grantnz's Avatar
grantnz
Default AIM Evo4 modifying tracks
Hello I have a EVO4 G-Dash SmartyHD combination. I have an annoying problem with a local track thats in the Aim track database but has the start finish line almost half way around the track from where it should be.
I have tried setting a new track manually from the dash but it keeps reverting to the position in the database.
I connected using GPS manager and deleted the track and then tried again manually setting the start position. Again no success it reverts to the database location even though I have deleted it.
I tried altering the position in the database using the "cursor pos" function. Seemed to work ok and it appeared in the location on the track map where I wanted it. Transmitted it but out on track again it still reverted and showed the lap time half way around.
Would anybody have any suggesions as to what else I might try. Thanks in advance.
Old 11-30-2015 | 12:19 PM
ProCoach's Avatar
ProCoach
Basic Site Sponsor
From: Durham, NC and Virginia International Raceway
Grant, the device doesn't know where start finish is unless GPS Manager shows it either on the EVO4 (when connected to it) OR the SmartCamHD (when connected directly to it or if there is a gps.config file on the card).
Make sure both are cleared and then load just the EVO4 with the desired s/f.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Old 11-30-2015 | 08:46 PM
amso3's Avatar
amso3
Default GPS coordinates
Grantnz
Look at your data and write down the Lat and Long from your data at the point s/f is really located. Then go to GPS manager and edit the track s/f coordinates and then save it to your computer. Then go to the EVO 4 and delete that track from the EVO and add your saved track. If your track shows up in your video, you can replace that file with your saved version also
Old 12-04-2015 | 04:20 AM
grantnz's Avatar
grantnz
Peter, thanks for those tips.
Was able to test that at the track today and SUCCESS finally after quite a few previous attempts.
Many thanks for your assistance
I just remembered one other thing I have never been able to achieve on the Evo4 as per the picture titles for the 2 data fields on the mainscreen ie "OilP" and "EngT"
Old 12-04-2015 | 09:14 AM
ProCoach's Avatar
ProCoach
Basic Site Sponsor
I just remembered one other thing I have never been able to achieve on the Evo4 as per the picture titles for the 2 data fields on the mainscreen ie "OilP" and "EngT."
There may be other ways, but the simplest is to connect to your laptop, open RaceStudio 2, select Device Configuration, select EVO4 and then "Go to," select Receive to suck down the configuration on the EVO4 currently, open the "Display" tab and under that "home" page selection on the left of the screen, rename (or assign in the first place) CH1 to OilP and CH2 to EngT in the little boxes. Then, press "Transmit" to send the newly edited config back to the logger and the dash!
Does it read information but not the right labels, now? If so, this will fix it.
Old 12-04-2015 | 09:53 AM
Matt Romanowski's Avatar
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
That's how I would do it as well.
Old 12-04-2015 | 03:39 PM
grantnz's Avatar
grantnz
Thanks Peter, sorry I should have explained more. That is how I have tried a few times.
Here is a receive out of EVO4 that shows how it should look but the labels never display on the EVO4 screen.
Old 12-04-2015 | 03:58 PM
ProCoach's Avatar
ProCoach
Basic Site Sponsor
That's strange. Could you transmit and check again? Otherwise, there may be an issue with the G-Dash display. Take a picture of your current dash, please!
Old 12-04-2015 | 07:54 PM
grantnz's Avatar
grantnz
Here is screen with ignition on but no running hence silly looking value
Quick Reply: AIM Evo4 modifying tracks
