MXL2 Installation Suggestions/Pictures in an early 911
With temperatures finally getting back to reasonable levels, I plan to install my MXL2 in Tweety Bird - a 1968/1973 911S (see my avatar). This is a PCA Club Racer in E running as a Prepared car.
I'm curious to hear suggestions/see pictures of any MXL2 installations in early 911's. I presume I will need some sort of mount similar to what was used in my Cup (thanks Jerry Austin!). I'd just like to see some suggestions if you guys have any. ViperBob, I know you put my old MXL into a 911. Got any pics?
Appreciate any and all suggestions folks!
Toby
Toby
Rennlist Hoonigan
which cost no drachmas
First one is an early 911 on a bracket connected to the steering column. Second one is my 914 with a dash replacement. The carbon fiber replaces the original gauge pod and the dash attaches to that.
Rennlist Hoonigan
I won't be with that car for a little bit. The brackets are usually just a basic "L" shaped bracket that screws or clamps to the steering column. I'm sure Jerry can send you a picture of what he did in his 911 too.
Yeah, I have the metal bracket that my old MXL was mounted to from my Cup. I can use that as a pattern. Just curious where is was bolted on at the steering column. One the Cup, there were four tabs on the turn signal/wiper stalks that I could use. Can't recall if there is something similar on the 911. Thanks all for the info.
Toby
Toby
