Shift light and water temp light not working ?
Old 06-15-2015 | 08:00 PM
bgiere's Avatar
bgiere
Default Shift light and water temp light not working ?
2005 996 cup has an AIM MXL Pista...does that dash replace or cancel out the stock indicators ? I have not seen the orange shift light come on and I got up to 250 water temp in the pits and did not see any lamp come on in the center console either.
Old 06-15-2015 | 08:25 PM
Matt Romanowski's Avatar
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
It depends on the install. If they disconnected the factory sensors and/or replaced them, then they wouldn't work. You will have to check out the installation.
Old 06-15-2015 | 08:59 PM
ProCoach's Avatar
ProCoach
Basic Site Sponsor
From: Durham, NC and Virginia International Raceway
Brant, super unlikely they would have disconnected or removed the water temp light. On the 996 Cup, the MXL config should get that info separate from the ECU and the alarm wold be set at the dash.
Same with the shift lights. The dash gets RPM feed from this model car through the same place that water temp comes from, two wires for all that info.
I would do a little digging, but the first thing is to connect to the dash, power it up, open up you computer and start Race Studio 2, go to Device Configuration, select MXL, then "Go to." At the top of the next page, select "Receive" and then click on the "system Configuration" tab at the top middle of the page and you should see something like the screen shot below. Make sure the shift lights are set up and that the alarms are set up. This particular config is for an old car that didn't have GPS, was a 4-cylinder with a redline of 6700 and had only wheel speed:
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Old 06-15-2015 | 09:22 PM
bgiere's Avatar
bgiere
Thanks, I have the shift lights and warning lamps set on the AIM dash, working perfectly...Just do not have the yellowish stock shift light or the water temp lamp on the center console lighting up. Shift light used to light up when I first raced the car I think...
Old 06-15-2015 | 09:38 PM
ProCoach's Avatar
ProCoach
Basic Site Sponsor
Spade lug terminals on the back of the indicator lights could have fallen off. Check that.
Old 06-15-2015 | 10:46 PM
Matt Romanowski
Rennlist Hoonigan
Do what Peter said and post a screen shot of the configuration and channels pages. That will tell us how it's set up and we should be able to give you some more specific places to look.
Old 06-16-2015 | 09:25 AM
bgiere's Avatar
bgiere
Will do asap, Thank You !!
Old 06-16-2015 | 11:39 PM
bgiere's Avatar
bgiere
Does anyone know what RPM should trigger the stock shift light ?
Old 06-16-2015 | 11:46 PM
Matt Romanowski
Rennlist Hoonigan
I don't know, but I would try Jerry. He knows Cups very well.
Old 06-17-2015 | 09:55 AM
amso3's Avatar
amso3
Default Shift light
Brant
The shift light is set with Modas. Not sure how your warning lights are set up. But Modas is used for that as well.
I have a very lightly used Modas MSA II box if you'd like to buy it, $800 shipped.
Quick Reply: Shift light and water temp light not working ?
