SmartyCam HD - Finally I got good Audio
Old 06-09-2015 | 12:05 AM
Curves's Avatar
Curves
Default SmartyCam HD - Finally I got good Audio
New on this forum. Autocross a 2012 MX-5 Miata. Posting here since you guys talk about the AiM products over here.
I got the unit on Friday. I love the automatic data overlay which is why I purchased it.
I was really really disappointed with the Audio like many others. I have the CAN cable with integrated MIC.
Playing around, the internal MIC was better than the external.
OK so bad cable? Then I looked at the cable/MIC and compared it to the MIC from my other camera. My other MIC had clear holes at the top of the MIC. The MIC on the CAN cable had holes filled up with yellow stuff. I unscrewed the top and it was packed with foam. I guess they wanted that to block wind noise? Well, it also blocks audio!. I tested it without the top and just put a regular small foam windsock over it. Now I have great Audio!
I still have to play around with Optimal Positioning for best sound and least Wind Noise. I have gain set to Manual with one setting above zero. Zero was too low gain, Two was too much gain. For now it is better than my Drift Ghost HD with external MIC which I was happy with.
Old 06-09-2015 | 12:15 AM
ProCoach's Avatar
ProCoach
Basic Site Sponsor
From: Durham, NC and Virginia International Raceway
Good news!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Old 06-09-2015 | 09:41 AM
Matt Romanowski's Avatar
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Awesome. Great news for folks having trouble with the external mic audio.
Old 06-19-2015 | 01:49 PM
kristap's Avatar
kristap
'appreciate the tip. Wouldn't have dismantled the mic without this.
Old 08-10-2015 | 12:20 AM
Geneman's Avatar
Geneman
quick question .. where do i find the page to adjust the microphone gain for either internal ( SC-HD bullet) or the mic integrated into the power or CAN cable.? is it in RS2? THANKS frank
matt/peter i updated the firmware.. which solved the huge background noise buzzing. but testing it at speaking levels in cockpit ( engine off, in garage) the unit still barely picks up my spoken voice ... i would like to play with gain on internal mike before i get the external ones.
thanks frank
Old 08-12-2015 | 11:46 AM
ProCoach's Avatar
ProCoach
Basic Site Sponsor
thanks frank
Frank, pretty common not to be able to hear too well spoken voices in a non-running test. Try it on the track.
Old 08-12-2015 | 03:32 PM
Matt Romanowski
Rennlist Hoonigan
I agree that people normally find the audio a little quiet sitting still, but on track it's at a good level. If you want in vehicle audio, the best way is the I/O Port adapter.
Old 08-13-2015 | 01:20 AM
Geneman's Avatar
Geneman
thanks guys copy that! best wishes frank
Old 08-13-2015 | 10:47 AM
Curves's Avatar
Curves
With the MIC mods I made in the first post, this is how my audio sounds. The MIC is located close to the passenger seat belt buckle. Great engine sound, no wind noise. At the end, listen to the speaking from me and those outside of my car.
Old 01-25-2016 | 12:23 PM
Eric5280's Avatar
Eric5280
I still was having issues with mine but just tried out a powered lav mic. Audio-Technica ATR3350IS. $22 on amazon and it gave by far the best audio (ok, still not great, but acceptable). I forgot to turn on the power to the mic and got the same electrical whine/interference. Next time out I turned on the power and it was much better. Wanted to pass it along.
Old 01-25-2016 | 12:33 PM
kk2's Avatar
kk2
Where is the built in mic on the SC HD?
I wonder how good something like this might be?
Amazon.com: Micover Stickover-Mini Universal Windscreen for DSLRs, Phones, Laptops, Small Video Cameras: Musical Instruments Amazon.com: Micover Stickover-Mini Universal Windscreen for DSLRs, Phones, Laptops, Small Video Cameras: Musical Instruments
Old 01-25-2016 | 12:40 PM
Eric5280's Avatar
Eric5280
Good idea, but I have found the built-in mic to be worthless. All non-powered options produced what appeared the be engine electrical interference for me.
Old 01-25-2016 | 01:00 PM
kk2's Avatar
kk2
Mine seem like ONLY wind noise
Old 01-25-2016 | 01:03 PM
Eric5280's Avatar
Eric5280
That is exactly what mine was doing as well and when I tucked the mic away it made all the electrical whine. Try the $22 powered mic, it should help hugely and Amazon is great about returns if you hate it.
Amazon.com: Audio-Technica ATR3350IS Omni Lavalier Microphone for Smartphones: Musical Instruments Amazon.com: Audio-Technica ATR3350IS Omni Lavalier Microphone for Smartphones: Musical Instruments
Old 03-12-2016 | 10:35 AM
Difool's Avatar
Difool
Hrm, I just went to great lengths to run the wires through the dash and center console and on testing the system I'm finding he same thing. There is a noticeable 1 kHz whine. I searched around a couple of the sound design, audio, and computer forums, and it looks like this is most often an issue of on-board power supply and DACs interfering, usually on the device/board itself. This means there's is probably not much to be done other than get this feedback to AiM.
I'll try messing around with the gain and other soft settings, and maybe playing with some grounded shielding anyway. If the diagnosis above is correct it would make sense that this is pretty common, and that using the cable from the DL with the jack, connected to an externally powered mic would work. But how could AiM release the external mic with that interference issue? The question is t outrage, it's hope that there is some configuration that works a bit better.
I have the SC HD GP, with the external mic wire from the SoloDL, which is, in turn, wired into the CAN directly. Any ideas or info?
Edit, also, I'll try the trick from the OP in case that will let the device record with less gain, and send the whine deeper into the background. (Hey, it's a theory)
Quick Reply: SmartyCam HD - Finally I got good Audio
