Aim Solo 2 DL, SmartyCam - One Continuous Lap
Hello,
Thank you to all who post and share information on this forum!
I purchased an Aim Solo 2 Dl and a SmartyCam 2.1 HD. By reading posts on Rennlist was able to wire it to the CAN Bus; it all works great, BUT....
The smartycamHD video replays show one continuous lap for the lap time, 30 minutes or whatever.
When I download the data off the Solo 2 DL, it is individual laps, the fastest lap time pops up, it works great...
The Track, Pacific Raceways in Kent, WA, is in the AIM database. In fact, there are two tracks to choose from in the AIM database.
What am I doing wrong? What setting needs to be adjusted?
Thank you!
Thank you!
Rennlist Hoonigan
which cost no drachmas
Did you transmit the track to the Solo 2 DL?
Assuming your in RS3 for analysis, when you import the data, it recalculates the lap times from the GPS, so it will always show the correct lap times even if the start/finish isn't in the device.
Yes, the track is in the Solo 2 DL.
I was just thinking... When I set it all up and tested the Solo 2 DL and smarty cam, I drove it around on the street. And used some weird setting for basically, "not on track"
I'm thinking I need to put it back in "race mode" or some such thing. I'll go try that in the garage and see what setting it is in.
ProCoach (03-02-2023)
