Replacement camera options
I inherited an old TraqDash system that utilized a Mobius camera connected via cable. Everything worked great until recently when the camera operation became sporadic. I tried a few different SD cards but the problem persisted. I have another Mobius camera (rear-facing) that I swapped over and it works fine so I concluded that the camera needs replaced. I don't want to use the rear-facing Mobius because it has a wide angle lens.
It looks like the camera I have is no longer available so I'm looking for a replacement that has similar functionality and price point to the Mobius. Any recommendations?
You may want to double check the settings on the camera that does not work. My rear facing camera stopped working and I found the settings had reset to the default.
