Michelin TC
I recently purchased new Cup2 tires and the Track Connect sensors that can be installed in those tires from Michelin. I had a chance to use them at the track and they work well, they provide temp and pressure and after a run you can see your progress on a graphic display around the track including time and G's. Supposedly their algorithms recommend adjustments for optimal pressure based on your car/tires/track/conditions and you can adjust the pressures while looking at the values on your phone app in real time after a run based on those recommendations. I don't have a lot of experience yet but for older cars without TPMS this is a good solution and I was wondering how many others there are that have used it and if there are any tips they've found to help me as I learn how to use it better?
