Anyone installed a logger controlled Accusump?
which cost no drachmas
The Accusump is a pressure reservoir. I don't agree with Peter's statement of "it pushes excess back to the tank but through a calibrated, slowing orifice that ALWAYS makes sure the main oil galley gets priority, thus ensuring safety for the lubrications system of the engine." The Accusump puts out oil when the pressure in the line it is connected to is less than that of the air in the Accusump. You need to make sure the Accusump is plumbed to an oil galley or supply hose that feeds the main oil galley. If you have it plumbed to a general feed or an oil filter, the oil gets distributed as it normally does (mains, top end, squirters, etc). The Accusump has no control of where the oil goes after it leaves the solenoid/ball valve.
One of the key things I learned was to use the latest "EPC" valves. The valve controls the flow, the logger just "enables" the valve. The latest valve is a one way valve that flip's direction when enabled.
Normally it is set to accumulate pressure, whenever the engine is making more pressure than is stored in the tank, the tank will slowly add pressure.
When the logger "flips" the valve, the valve will no longer receive oil, and wont discharge any until the engine pressure drops below what is stored. So if there is no issue, the tank stays full.
So the trick is to flip the valve and prepare for trouble "just in case"
I set mine pretty high, RPM>2500 (I really don't care what happens below that) and Engine OilP<50psi (as long as there is 50, I "think" it will survive), this keeps the oil in the tank full, and ensures only in emergency does it discharge.
One thing I have been meaning to do is trigger based on a math channel, so I can chart the math in RS3. With it set as only a trigger, you cant see the logic in action, only the resulting oil pressure gains/drops.
You can see in the graph below oil pressure stays above 30psi. While not ideal, i was dropping into the single digits before the accusump.
I am going to be honest, ProCoach your condescending know it all commentary had put me off contributing to this thread. The benefit of community forums is for the discussion of ideas. Comments like the below, with no further information discovery, kill the discussion by claiming to have ultimate knowledge.
Any conditions to set the logic in the logger to actuate would be too late based on the fact that a low oil pressure condition would already indicate potential damage. Also, no way for the logic to control the critical slowing of the flow back to the Accusump when the crisis is past.
To do so I will use the AiM EVO 5 and two of the analog channels. I have these super handy debug cables I made with Wago 224 connectors, Tefzel, DR-25, and Binder 719 female connectors. Makes it very quick to prototype wiring configurations.
The test rig uses a 1/4 NPT Schrader valve for pressurization on a Tee with a 1/8 NPT female and 1/4 NPT female connection. This then has the GEMS pressure switch and an AiM 0-150 PSI (X05PSA00150P18K) pressure sensor.
And this is what the data look likes. Blue is the pressure while red shows the switch activation through voltage measurement change on the analog channel. Even with pressure changes happening pretty slowly (time on the X axis) the GEMS sensor misses it's deadband specification by transitioning at 29.7 PSI and 30.8 PSI when pressure is falling. It does better when pressure is rising and meets specification.
The point of the above is the Accusump solenoid control system as supplied is better than a lever, but a low precision system. It is perfectly fine for a $40 switch. There is no magic to it, either the switch is on or off and the solenoid is activated or not activated. The performance of this system can be easily surpassed with almost any digital control system, especially one as expensive and feature rich as the AiM EVO 5. More importantly, it can take multiple inputs for the logic used to control the solenoid on the Accusump. My data is showing that Yaw rate is a leading indicator of a soon to occur low pressure event when combined with heavy braking. Rather than wait for oil pressure to drop and respond, pre-empt the pressure drop based on Yaw rate changes from my front axel IMU and long_acc.
I think you're on to a great solution. Although, I'd have to feel real comfortable with the consistency of gating the accusump via yaw and long_acc.
Can't you start with just oil pressure and rpm, and look at post event data to see if that's enough? Or, I'm not familiar with the EVO5, but if you could install a math channel to watch rate of change of dropping oil pressure, that might create a early warning also.
You could also plot oil pressure vs Accusump valve position to see the scatter of the opening/closing pressure from a session I presume.
Basic Site Sponsor
Thanks for your share. Very good information and well done. Again, will try to do better.
I learned something.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
In its original configuration, the accusump was a simple hydraulic pressure accumulator, there was no valve separating it from the engine. In this configuration the accusump responds in real time to every fluctuation. This is the ideal scenario.
Is does create other issues,, like flooding the sump and exhausting its supply too early. So the valved solution was added as a work around. This by itself slows the response way down.
now adding a logger/controller to mix adds more delays. 1) where are you sampling pressure from? Depending on where you install the pressure sensor, can add delay as it takes time for the drop to propagate through the system. 2) Aim logger is not a real time CPU, there is no guarantee the aim system is not delayed just at the moment you need it.
Risk/Reward... its not a perfect solution, its not guaranteed to save your engine, but I think it does increases the odds back in my favor.
Basic Site Sponsor
My experience with the included electric solenoid is that the discharge from the accumulator is much quicker than the return rate allowed back to the accumulator. I like increasing odds!
As a side note, my car is heavily tracked, but driven to the track. Having the Accusump dumping it's contents into my sump when the car is idling at some lights is not desirable. My tying the control of the Accusump to the data logger, it won't be freaking out at low idle pressures.
