Don't know. I separate each test file and select one test per run. I don't merge the files.
__________________ -Peter Krause www.peterkrause.net www.gofasternow.com
I'm not sure on the merged files. It's been a discussion I've been having with the software team. For me, they do not work. When downloaded merged, the sessions don't typically work and create some problems. When downloaded separately, the sessions do work. Even when downloaded merged, there are multiple XRK files created and they don't seem to display correctly. Right know the only option is to open all the sessions and use global time to view them.
Matt, Peter, thanks for your patience and help. Appreciated.
I've sent AiM a handful of bug and feature requests over the last few days.
Another nuance, on the MXm, manually selecting a track isn't saved until you exit the map selection page. I may have powered off after manually selecting a map, but before backing out of that menu-page to force the save. I don't know.
One more thing while I'm here, RSA3 has a lot of unused white space above the active windows when using RA3. I'd love a "shift-spacebar" option to hide the higher level menus at the top, and expand the analysis space vertically, similar to "spacebar" option. That would increase analysis space by 20-30%. And/or, have a floating menus option. Vertical space is extremely valuable.
A full screen option would be cool. You can do it when you un-dock windows, but not on a single screen. I do use things differently when on multiple monitors or with a TV vs on the laptop. I'll mention it to the software team.
