Is everyone happy with their SmartyCam?
Basic Site Sponsor
Basic Site Sponsor
Received 2,896 Likes
Be sure to set your Menu>Settings>Accel Cal>Select on level ground after you’re happy with the preview and then back out using the center button.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Thanks peter. what does the accel cal>select>ground level do? in my case, the remote box is mounted on the tunnel near the gear shift. so it is " ground level. i assume the accelerometer sensor is in the box, not the pencil cam unit itself
I don’t recommend the 120 due to the distortion and “warp” at the edges of the field of view. I have sold a few to open wheel and sports racers, as well as to those who wish the widest view to protect themselves from the rear view.
Also, the usable vertical view of the 120 is limited due to the fixed 16.9 aspect ratio.
Basic Site Sponsor
Basic Site Sponsor
Having the car on level ground allows the accelerometers in the background of the video to be centered, which is important. This is true for anyone running a SmartyCam, especially if you're going to use RS3A-beta to look at SmartyCam generated data.
Basic Site Sponsor
Basic Site Sponsor
jwasilko (07-11-2020)
While it adds validation, depth and an objective measure to assign a steering angle number, I find that a vast majority of people watching the video can more quickly and easily assimilate steering input amplitude and speed, as well as shift speed, FAR more easily using the video than constructing a strip chart.
GT3_Driver (07-16-2020)
Basic Site Sponsor
Basic Site Sponsor
I’ve been using the SWAngle feed in a control on the video, since I can’t always see the SW easily in the vid (need to set my exposure, the inside of the car is often too dark). I agree the linear bar widget isn’t as intuitive as a rotating steering wheel animation. Please suggest to AiM that we all want a SW widget for the video data display! 😀
Rennlist Hoonigan
which cost no drachmas
If you use beta, you have the video and the actual angle from data in it. The data tells you way more than the video for steering.
Basic Site Sponsor
Basic Site Sponsor
Both, is best.
I had my first outting with the SmartyCam this past weekend. It was connected to my Aim Solo 2 DL which was hooked up to my Cayman's canbus. Everything worked perfectly!
720p res is a little disappointing if you're used to using GoPros, but it does the job and working with the smaller/lighter files is a lot faster and easier.
Also, the mic is picking up terrible wind noise. I saw a few threads on that so i'll read up.
Basic Site Sponsor
Basic Site Sponsor
4K, by itself, is easy. That file size, tho...
Even 1080p is a very big challenge to render animations ON to the video in real time.
Also, the resolution is only part of the issue, a better codec (H265) with lower native resolution is better than a higher resolution with a crappy codec. Many more factors than just a number.
Plus, I can coach better using 4K, said no ProCoach, ever!
I can coach better using metrics ON the video, available twenty seconds after you return to the paddock, said EVERY pro coach I know.
Glad you have a good solution now.
Rennlist Hoonigan
I agree with Peter. There are a lot of technical problems with moving a camera like the SCHD to 4k, not to mention availability of the sensor element in appropriate quantities and price.
Not really. I've done lots of work in robotics and computer vision and you can overlay real time rendered graphics on 1080p video real time with a $35 raspberry pi. Motorsports is a small market, but its also a market quite willing to support high margin products. If you think about it, Aim's business plan is literally selling 10yr old technology at a premium price.
FastCarSlo (07-26-2020)
Happy SmartyCam Camper
I'm getting so sick of futzing with electronics while at the track only to have them rarely work, or i forget to hit record on the GoPro, etc, etc. When video does work i rarely get around to processing videos and overlays. I have an Aim Solo 2 DL (wired up to CAN bus) and am thinking about getting a SmartyCam to make life simpler. It is pricey, though.
Is it truly "the dream"? Does it always work? Pretty videos will pop out perfectly as if by magic? Is the video quality good?
What are the cons?
Thanks!
What are the cons?
Thanks!
In my experience, there are four (4) AiM dealers in the US that offer high-quality service and support: Peter Krause, Matt Romanowski are 2 of the 4. They support Rennlist to the nth degree. I have a good solid dealer in Paso Robles, CA at Veracity Racing Data, 10 miles from my home. I have another dealer in N. Hollywood. Those are the only four (4) I know of. If you buy from anyone else, it may be the roll of the dice, could be excellent, could be the pits.
You could sell your SOLO 2 DL and go to a V-BOX Lite, Peter sells these. You'll have two cameras...do you need to supplement with a rear-facing camera? If you are wheel to wheel racing, it's a good idea. V-BOX Lite can be wired into your CAN bus, as far as I know. Talk to one of the dealers mentioned, they'll set you straight.
VIDEO:
Basic Site Sponsor
Basic Site Sponsor
I am ecstatic about the performance of my SmartyCam HD, Rev. 2.1 with 84 degree field of vision (FOV).
The wind noise is horrendous so turn down the volume. I think I have that fixed.
I have just sent several mics to Ellen at Veracity that, together with the 3.5mm mic jack cable between the S2DL and the SCHD in your car, will fix that problem.
Make sure after that is installed that the audio gain settings are turned off internally and in the middle for the externally mounted mic.
