Motec C187 Install
Motec C187 Install
Finally posting some pictures of the work on my C187 install with custom steering wheel. I’ve done all the work on this myself with the exception of cutting the carbon fiber plate.
this is my second Motec install, and there is a lot I’ve learned from the first one. First, it takes a lot of planning to do something this complex. Second, document everything...literally every pin in the harness, or you’ll regret it later. Third, it helps to have a little help from a real pro. Chris Brown did all the CAN templates and helped QA my pin out before I twisted a single wire. Last, do lots of research on how to build a really good harness; it takes a lot of customs tools, none of which are cheap.
In addition to the CAN data i’ll have 10 Hz GPS, Izzy 6 DOF IMU, oil cooler in temp, oil cooler out, 2 KA combo oil pressure/temp sensor (one on each head), shock pots, Izzy tire temp/pressures, plus a whole bunch of inputs/output for the various buttons on the steering wheel. I’ve built the wheel so I can eventually make it CAN only, but that’s a future upgrade; for now it uses all 22 pins in the Krontec disconnect.
Next up in the project is finishing off the center console, which I hope to finish over the holidays.
[img]
[img]
Basic Site Sponsor
Basic Site Sponsor
Received 2,837 Likes
Congrats! Great work.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
This is pretty cool stuff. Thanks for sharing!
Basic Site Sponsor
Basic Site Sponsor
Impressive. I’ve done something similar with a c125. Im using the ecu master can switch in my steering wheel, which supports 8 buttons and 2 dials.
Question - how did you make the decals/labels ?
Sweet!
Rennlist Hoonigan
which cost no drachmas
Nice work!
What CAN analyzer is that? I've been considering a new one, but not sure what I want. I've been doing a lot more CAN work.
you too! SPC is a great class!
