AIM Solo - Not timing
I've got an early AIM solo...like pre-order early version of it. It's always been flawless in it's operation, battery lasts for what seems forever, thing is just solid and never a worry.
Earlier this spring I added a couple of new tracks to it and updated my really old firmware version at the same time. Mine you the latest firmware update is almost 2 years old at this point but the one I had in there was older.
Since the firmware update it just doesn't work anymore.
The device comes up and will get 8-10 satellites locked in, shows the proper track, but will rarely register a lap time. I'll go out for a session and it does nothing for like the first 3 laps and then suddenly recognizes a 4-5 min lap and starts to do +/- reading on that 4 min lap. Then it'll register like a 2 min lap and then finally maybe one good lap and then just quits doing anything...either freezes at a +/- value or shows some random number that has nothing to do with anything it's recorded thus far that session.
Still shows good satellite reception, has full battery, everything indicates it's in good working order.
I've moved it to a different location in the car to verify good GPS signal, still the same behavior. The really weird part is it'll get like one good accurate lap per session and the rest of the time it's garbage data.
Anyone seen this before? I can't revert hardware versions to anything near as old as what I had.
AIM just says send it in an then tells me about the shiny new one
Rennlist Hoonigan
which cost no drachmas
If you take the data and do a GPS lap insert, does it then give good data?
Is it a track that it worked at correctly before? Some tracks that are pretty wide can be a problem if the track width isn't set wide enough. Pocono is a frequent problem on this.
Basic Site Sponsor
Basic Site Sponsor
Received 2,845 Likes
Widen the track width from the default to the next wider option. Possible without a computer on the device in Settings.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Gents, Thank you for the suggestion on track width. Now that I think about it I changed it while I was at New Castle racing karts around the same time this started to happen...I'm betting that's the issue.
Do you know what the default is for track width and what you've had success with at most tracks?
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
The other thing I periodically do is delete all the tracks on the device (after insuring the firmware is up to date) and reload the tracks that I know I’m going to. It is possible for the track database to become corrupted.
Basic Site Sponsor
Basic Site Sponsor
Having similar issues. Was out at Chuckwalla this past weekend and it worked for the first two outings, then did not for rest of day. Was using the Cosworth data during the day so didn't notice until I got home. What's weird is that the track map and car cursor is still moving inside the video, which was not the case in the past when it did not record lap times. I'll try widening the width. I'm pretty bummed about this. I feel like this thing works only about half the time on average for recording lap times...And yes, every time I go to the track I delete all my maps and reload them. S
