AiM Fuel Pressure Sensor
Basic Site Sponsor
Basic Site Sponsor
Received 2,846 Likes
No, but I have RaceGrade units, if you're interested. A little better than the KA's but I estimate it will be at least after April 3-4 before AiM Sports USA has the KA's again.
I bought the last in inventory from Summit, WR, Discovery Parts, OG, Pegasus and a few other vendors to complete large system orders that were missing these.
With the connector and 719 end added, the RG sensors are $208.
I would NOT recommend mounting any on the fuel rail itself. A pigtail of aeroquip will take a lot of the stress off.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Basic Site Sponsor
Basic Site Sponsor
I’m sure the Kavlico is fine. There’s even a drop down menu for sensor scaling in the AiM config software, but I wanted something better. https://www.milspecwiring.com/DATA%2...20G2%20DTM.pdf
I include a DTM3S to 719 lead, a -3AN female to 1/8” NPT adapter for that price. And the scaling is exactly the same as the KA PRS-837 so it can be substituted without change to the config.
My new engine build with a MoTec M130 ECU is going to use the fuel pressure sensor I bought from you for oil pressure. I want to mount it off of the engine so there is less vibration.
Basic Site Sponsor
Basic Site Sponsor
I make them up myself, adding NPT male (or metric male) to AN male fittings, then a made up hose with two female AN's on each end, then the appropriate male AN to female accept-whatever-the-sensor-male thread is.
Take a look at this page from Pegasus. https://www.pegasusautoracing.com/gr...=PRESSADAPTERS
The appropriate threaded adapter and copper seal ring at your engine end could then use the Autometer kit on the bottom of the page. Quick, easy and safe.
Has anyone ever had a RaceGrade M APT-G2-DTM-150 (0 - 150 psi) pressure sensor fail when mounted to the engine? After all, 911 flat six engines have perfect primary and secondary balance and are low in vibration. I could understand if this were a V-6, but it i not.
With my previous engine, I mounted an AiM pressure sensor right on the engine and it was fine all the years I had it that way.
Basic Site Sponsor
Basic Site Sponsor
I would never recommend any sensor be mounted directly to the engine, always with a short length of braided line.
It's been two years, but I'll replace your sensor if you can send me the old one back.
Peter,
Thanks, but the RaceGrade sensor you sold me is fine. With the old engine setup I used it with my AiM MXL2 dash for fuel pressure and it was at the front of the car by the fuel pump (it should have been after the fuel filter, not before it....). With my new engine I will use it as an oil pressure sensor with my MoTec M130 ECU. I am just trying to figure out if it really is bad to have the pressure sender on a 911 engine. I had an AiM oil pressure sensor directly on the engine and it worked great for years.
I would never mount an oil temp sensor anywhere BUT on the engine right where the oil is flowing. The cam sensor is mounted on the engine. The crank sensor is mounted on the engine. The CHT sensor is on the engine. The knock sensors are on the engine. The TPS is on the ITBs which is on the engine. In fact, the only sensor that it appears you don't want to mount on the engine is the oil pressure sensor....
Scott
Scott
Rennlist Hoonigan
which cost no drachmas
I have not had an AiM made sensor fail that was used correctly. They are very robust and get great testing at the factory for calibration of pressures, temps, and operating environment. I did have some KA sensors fail, but I'm not sure exactly how many. Not a handful in the years they made them for AiM.
Temp sensors are a junction, so they are not affected by vibration or operating range temps. Pressure sensors can be influenced by temp and vibration in their readings and life span. I mount them on engines all the time. Everything from multiple V8 manufacturers to off road UTVs, motorcycles, baja buggies, and all sorts of road racing. They live fine on the engine, though "proper" mounting is with a hose in a vibration reducing mount. My 914 with a 2.7 and later 3 liter motor has always had one screwed into the case directly and it's been fine.
Basic Site Sponsor
Basic Site Sponsor
As a professional mechanic for decades, I did see a number of bulb-type VDO and Veglia oil pressure sensors, all mounted directly to a threaded port in the block, fail over time, both internally and also leaking externally. Maybe that’s the reason I’m paranoid about those specific sensors.
In the beginning, I sold a few AIM diaphragm type VDO sensors, but as soon as I discovered the MSI solid-state sensors, I never sold another diaphragm type again.
Then, the KA sensors came out and my experience was quite different from Matt’s. Out of nearly eight hundred sold, I had a significant number of external fluid leakage and output failures on the brake pressure sensors (almost always immediately after installation, so if they worked, they worked), and some with no output on the 0-150 range.
This was the reason I started selling the RaceGrade sensors, to avoid issues near the end of KA’s time as a supplier to AIM.
I’ve sold more than a hundred of the new AIM pressure sensors. So far, so good.
As Scott and Matt point out, the PT100 temp sensors and the rotary and string pots sensors mounted solidly work fine, but I’m still recommending fuel rail and oil pressure sensors be mounted remotely using braided line from the main galley. YMMV.
Rennlist Hoonigan
I don't count the VDO sensors in the same category as a Motorsport sensor. Those are far more failure prone and I've never advised them and only ever sold maybe 2.
The AiM sensors are pretty amazing. I've seen all the board design, actual manufacturing of the board (component pick and place to oven), packaging, multiple testing fixtures, and finished product. It's impressive! Part of the reason I was the first dealer to have them and have sold so many.
