SoloDL - CAN vs. OBD-II - can't compare data?
Is there a known limitation that data collected by differing SoloDL versions (CAN vs OBD) can't do data comparisons?
I've got the CAN version in my car (2010 Cayman S). My buddy has the OBD version in his car (2016 Cayman GTS).
We both did the same DE event and wanted to compare data traces. I sent him my data and he said he can only overlay the GPS stuff - the other data traces (TPS, brake pressure, etc) won't overlay.
Is that normal? Bummer if it is. If not - is there some kind of trick or something to get it to work?
Rennlist Hoonigan
which cost no drachmas
All data from all AiM devices is able to be overlayed.
I'm guessing what his problem is that the channels have different names, so if he is trying to put the traces over each other, he'll have to use the tiled view. Check the image. Then he'll have to select the measure number to the left of the measure to overlay the channels he wants together.
