AiM ECU Bridge CAN + MoTeC C125 + 996 Configuration
Looking for some troubleshooting help on my race car setup:
- MoTeC C125 w/ boost and oil sensors
- AiM ECU Bridge CAN
- AiM SmartyCam v2
- 01' 996 Turbo w/ stock ECU and dash gauge cluster has been removed
The main issue I'm facing at the moment is that the RPMs are not showing on the video display while using the SmartyCam. No issues with the MoTeC C125 display while driving so I'm guessing it's related to the AiM ECU Bridge CAN configuration. The shop that did the initial setup selected the BOSCH 996 ECU from the AiM configuration picklist.
I have a track day next week and don't have time to tow it back there so looking for some help here. If you have a similar setup, it would be great to see your AiM configuration file or a screenshot of the settings. Thanks in advance!
Cheers,
Scott
- AiM SmartyCam v2
Cheers,
Scott
Basic Site Sponsor
Basic Site Sponsor
Received 3,340 Likes
- AiM SmartyCam v2
Cheers,
Scott
- AiM SmartyCam v2
Cheers,
Scott
You could conceivably use OBDII or ISO 9141/2 CAN, but this would NOT work very well (not updated quickly enough). Might look ok on the SmartyCam gauges (RPM, TPS and ECT), but there would be BIG lag and latency.
Best bet is to set up the ECU Bridge for MoTeC VCS_Compound Transmit protocol and make a direct connection to the C125, but then you will need to add the VCS_Compound Transmit config to the CAN out in the C125 configuration. http://www.aim-sportline.com/downloa...0k_101_eng.pdf
In every case, you will need a GPS-08B antenna (four-pin, for the SCHD) to get speed, lap times, track map and lap count on the video, whatever your connection to the car is, either MoTeC or Bosch ECU. John Reed might be a good local resource to you.
Basic Site Sponsor
Basic Site Sponsor
Where is the ECU Bridge connected to?
Premium Sponsor
I am planning to do almost the same combo as the OP, except I have the Motec CDL3 track kit with Motec 10 Hz GPS. Wondering does anyone know if a separate AIM GPS is required for the AIM Smartycam and AIM ECU bridge, or the Motec GPS data will be read by the ECU bridge along with the other Motec data?
Thank you in advance.
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
TPC Racing stats:
Basic Site Sponsor
Basic Site Sponsor
The ECU Bridge takes the output of the CDL3, MoTeC's VCS_Compound_Transmit protocol channels and sends them to the AiM SmartyCam.
GPS measures and GPS speed are not included in the output of the Dash. But throttle position, RPM, brake pressure and some others are and that is used to put information on the background of the video.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Premium Sponsor
A separate GPS-08B antenna IS required for the SmartyCam SCHD with a CDL3 Track Kit and a GPS-L10 to show lap times, lap count, speed and track map on the SCHD.
