Foam cannon cloged
My MTM uber Foam cannon has clogged up and will not flow soap thru.
Any suggestions for unclogging?
Thanks.
Thanks.
I'll try that. Thanks
Either air or you will bed to take apart. The front tip, is where the filter located. Not hard at all. Take those pieces out, blow it out, then it should fix it. I clean my every month to maintain it.
